Old 11-12-2009, 03:15 PM   #1
justin lilley
20B
justin lilley's Avatar
justin lilley is on a distinguished road
? Decode Serial #
>> any one know how to decode a serial # I have what i think is a 84 gsl.se it has a fuel injected 13b in it for sure .. i am having problems finding rotors for the rear disk brakes .. the origional rotors were were solid and not as thick as the vented rotors i keep getting sent
..i am windering if i have a 12A car that has had a motor swap and been rebadged ..and the rear disks are a 12A option .. mine are the type with the Ebrake built into the brakes caliper here is the serial # if I know what it started life as that mite help me ??1984 MAZDA RX7?? JM1FB3322E0802155
justin lilley is offline   Reply With Quote
Old 11-12-2009, 04:05 PM   #2
PercentSevenC
Custom User Title
PercentSevenC's Avatar
It's a GSL-SE. If the rear discs are solid, someone swapped in a GSL rear end. Are your wheels the same front and rear? If so, your front suspension has also been swapped to 12A spec. Either that or someone swapped VINs for whatever reason, but if it has an injected 13B, I'd be more inclined to think someone yoinked the suspension to use in their 12A car.
Old 11-13-2009, 09:48 AM   #3
Rogue_Wulff
Non Member
Another clue as to whether the car has the 12A brakes is the wheel size. If it has 13's, they must be 12A brakes, as 13's won't fit over the SE brakes. Also, the 12A hubs use lug bolts or screw in studs, while the SE hubs have pressed in studs.
I'm betting you have an SE with 12A brakes.
Old 11-13-2009, 01:22 PM   #4
plus the rear rotors are vented on GSLSE cars
EDIT oops already mentioned.
Old 11-13-2009, 02:54 PM   #5
rx4ur7
Rotary since 1972
rx4ur7's Avatar
JM1FB332 is 13B JM1FB331 is 12A
