Old 11-10-2009, 11:35 PM   #1
Drama
Drama's Avatar
Drama is on a distinguished road
Smile S5 T2 Roller.(with tranny and driveshaft)
Car is a 1989 Red T2, Vert seats, Converted over to manual windows, Front and rear strut tower braces, stainless steel brake hose`s, almost new hawk hps pads, battery relocation performed. N/A wheels with almost new bridgestones on them painted bronze, coil packs go with car.
T2 hood missing.
No engine, harness, ecu, radiator, no sway-bars, no battery.
Asking $1500.00 o.b.o.
The car was fixed up to do track events, I only have had the time for one which was back in 8/08 and not really drove since, I`am taking the things I want from it, And letting some of the items go with the car, More pictures later in the day, The Cage is up in the air, Someone wants it with the car I`ll sell it for A small bit more.
10th A.E. with 94 Twin Turbo FD Engine, With a precision turbo SC 60. Tokico Blues, B & G springs, Racing beat sway bars, Fender braces, F & R strut braces, Stainless brake hose`s, Toe eliminator busings, Carbon/Kelvar GT300 hood, Depo Gauges,Catz fogs,Sparco 383 steering wheel, 3rd gen shifter knob.
Falken Anzenis Rt 615`s
Front wheels 17X8+35 245/40
Rear wheels 17X9+44 with 5mm spacer 275/40
Drama is offline   Reply With Quote
Old 11-11-2009, 09:59 AM   #2
Drama
Drama's Avatar
pictures of the engine bay as of this moment. Am removing this stuff as I type.
Old 11-11-2009, 10:20 AM   #3
Drama
Drama's Avatar
Last pictures
Will sell car as complete as seen in pictures.
$3500.00
Mileage on odometer is 110944. Engine is a reman mazda with 10,000 miles.
S4 N/a with a RB header, RB main drive and Alt pulley, Act pro lite flywheel,
clutch is a stock unit from advance auto, Also has a RB oil scavage plate. Some cheap mufflers. If someone wants futher pictures just p.m. me with a e-mail address and what your interested in seeing, I`ll get them too you within 24 hours. The WEDS Sports wheels weigh 14.1 pounds and I have a 5th one which has never been mounted. Tires on the wheels right now are Michlen Piolt Cup road race tires. Also has RB sway bars with there adjustable end links for front and rear. The ecu has a Oil metering delete from Rtek.
Old 11-19-2009, 04:56 PM   #4
So let me understand this - its a S5 T2 without a turbo engine, t2 hood, t2 wheels, t2 seats, etc ????
I'm not trying to slam your FS thread, but it sounds a bit, um - off.... the only thing I see T2 are the fender decals...
Seems like a lot of work to convert a T2 to NA status. I like the S5 MAF on the S4 engine too.. does the car retain its S5 engine harness and ECU then?
Very confused...
Old 11-22-2009, 11:40 AM   #5
Drama
Drama's Avatar
Too much work, And yes It does have the N350 harness, And N350 ecu with the Rtek oil metering elmination modifcation.
Old 11-22-2009, 02:44 PM   #6
fire85gslse
fire85gslse's Avatar
Good seller.
Here is info that will help ad if you can answer it.
Vin is it a T2 car or NA car?
Clean title?
T2 suspension and tranny/rear end?
$1500 for a roller with out the cage or with? (Seems high without, good with)
Old 11-29-2009, 03:02 PM   #7
Drama
Drama's Avatar
Vin#
jm1fc3320k0703164
Old 12-14-2009, 04:52 PM   #8
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
That would be a T2 Vin.
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
Old 01-04-2010, 05:33 PM   #9
Drama
Drama's Avatar
am going to put a smallblock in the car, I`ll start listing parts am selling as I go.
