Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > SakeBomb Garage
SakeBomb Garage SakeBomb Garage "OEM appearance, uncompromised performance"
Old 10-23-2009, 01:17 AM   #1
3RotorMotor
3RotorMotor's Avatar
3RotorMotor is on a distinguished road
Lightbulb GB: Bi-xenon HID PROJECTOR - SakeBomb Garage
SakeBomb Garage presents:
We all know that the stock headlights on the Rx-7 are vastly inadequate for driving at night. We finally decided to fix this problem once and for all. SakeBomb Garage is pleased to offer the first and only true 'pop-up' Bi-Xenon Projector HID kit for the FD.
FD owners: Welcome to the 21st Century.
HID Lighting 101:
Other HID “kits” use the stock headlight housing in conjunction with a Xenon bulb. The plus side, they are unbelievably cheap. The negative side? Typically these setups:
-blind other drivers
-have a horrible field of view
-severely scatter the light
-have uneven lighting with no cutoff
-actually WORSEN your night vision (they throw intense light into the foreground (actually making your pupils close) causing your distance night-vision to become worse than with your stock halogen lights)
Projector HID's on the other hand are what is used in every OEM HID lighting setup. Our Projectors:
-Have a very even dispersion of light
-Have a very wide dispersion of light
-Have a very long throw (with high beams)
-Illuminate much larger portions of the road while not ruining your night vision
-Oh yeah, and they don't blind other drivers, or attract attention from people who may or may not drive Crown Victorias
To truly see the difference you need to see our kit in person, pictures honestly don’t do it justice.
The SakeBomb Garage Projector HID kit is plug and play. Simply pop out your own lights, trim the headlight bucket, pop in the new lights, and connect the ground and power cable.
HIGHLIGHTS:
~New headlight housings, with bi-xenon (high/low) projectors
~Optically clear projector lenses
~New (OEM) Philips 4300K bulbs.
~High quality 35 watt weatherproofed ballast
~Plug and play wiring harness specifically for the FD
At the request of a few forum members, we are offering as an option the Mistubishi Generation 4 35w OEM ballast, to replace the aftermarket ones included in our standard kit. Functionally these are the same 35w output as the aftermarket ballasts, so the light output will be the identical. It's basically a name brand vs generic choice, but we wanted to give people the option to choose.
Pricing:
$750 - Standard
$830 - Upgraded Ballasts
(Buyer pays actual shipping cost)
As you can clearly see (no pun intended ), these are not your cheap h4 conversion kit lights. There is an unbelievable amount of work which goes into creating each kit, but once you install these lights in your car you will quickly realize why you could NEVER go back to anything else! This kit, while retaining the stock appearance, brings to the FD the lighting quality and output of this decade!
NOTE **Unfortunately we got our subforum on RCC a little late. The current GB we are running is ending at the end of THIS MONTH (OCTOBER)!! Payments must be made by Nov. 1st to be included in this GB. **
Please include (Forum name), (Standard/Upgraded Ballast), (Your zip)
1.
2.
3.
4.
5.
3RotorMotor is offline   Reply With Quote
