Old 10-20-2009, 01:49 PM   #1
rx4ur7
Rotary since 1972
rx4ur7's Avatar
CPU water leak recall, horn, turn signals, warning system
I would think this is old news. I thought I saw a post that was relating to this issue.
RECALL #031/86 10/3/86
CPU Damage from Water Leak
Some early RX7's have had CPU damage caused by water leakage. Symptoms include:
  • erratic or no horn
  • erratic turn signal and emergency light operation
  • erratic or no 'beep' warning signals
Leakage occurs around a metal flange (upper left inner body under left fender)
Fix from Mazda:more sealant applied to area during production and protective coating added to inside of CPU.
Field fix; sealant applied to area, replace CPU if damaged beyond cleaning.
I have had to repair a few of these, I would think they have all been taken care of by now. Need to check CPU and fuse block for water damage also.
Old 10-20-2009, 05:02 PM   #2
SecondGenPat
Start a Revolution
SecondGenPat's Avatar
SecondGenPat is on a distinguished road
Is this area by the drivers door jamb where the door hinges mount? That's the only body rust spot I have and I am also experiencing the same issues.
Thanks
That to secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, — That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
-The United Stated Declaration of Independence
SecondGenPat is offline   Reply With Quote
Old 10-21-2009, 01:02 PM   #3
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Yes, up and forward of the top hinge. On the guys I did you could see where it was by using a light from the outside then looking up inside.
Page 105 Service Bulletin 1986 book. 9999-95-008N-87
