Old 10-19-2009, 10:43 AM   #1
BigIslandSevens
BigIslandSevens's Avatar
Easy fix for rattling mirror glass
Hey all,
My mirror glass( L & R) were rattling something fierce. It drove me crazy. So I decided to try to end the issue. I tried glue:=Fail
What I ended up doing was buying a $4.00 can of "great Stuff" insulating foam from Lowe's. I then drilled a 1/4 inch hole in the bottom of each mirror. Stick the end of the can's straw into the hole and I filled it until the foam blew back out the hole. NOW! This foam is expanding!! So be sure you have a big enough hole to let the gases escape and the foam expand. The foam can and will deform the plastic surrounds if not able to vent. And/OR Break the glass itself)
Mine turned out great. NO more rattle at all in my hands. You may need to trim some foam that comes around the glass off, but it trims really easy. A paper clip did it for me
Anyways, 4 dollars and less than 20 minutes of work time involved, and no more rattle. I am painting the mirrors now, but unless you need to just be carefull and it will turn out clean.
Dave
Old 10-19-2009, 05:54 PM   #2
BigIslandSevens
UPDATE: Again, make sure to keep a vent hole open. My passenger side clogged up and about 20 hrs later just exploded in front of me on the bench Kinda expected one to blow. Trying to keep the other vent hole clear.
FWIW: It didn't rattle at all before it blew to pieces
Old 10-20-2009, 12:24 PM   #3
rx4ur7
Rotary since 1972
rx4ur7's Avatar
A little less messy method is to remove the mirror, just the mirror part, pop out the two spring roll pins, use something to open them up a bit. A nail, awl, a couple of those little snap-on pocket screw drivers. Pop them back in, install mirror. Have done this on nearly all my clients cars. If they are tough to get back in place you have it right.
They can also be done while still in place. Generally you may have to have a couple of tries at that way though because you can not get the end splayed as much as one needs. And they usually pop out on you anyway.
When it comes time to do repair to the wiring or switch this procedure might make that a lot easier.
OPPS Sorry, this is for the interior mirror. But if you do that don't you loose the ability to adjust them?
I think there are some other things I might try this on though. Thanks. .
Old 10-20-2009, 01:14 PM   #4
BigIslandSevens
That repair is for electric mirrors? If so then yes i do not reccomend using the foam filler method.
Mine are 81 non electric mirrors. Not sure if the same thing can be done. I don't see any spring roll pin on the inside of the one that broke that can be stretched. It only made a real mess when it blew up It was an experiment for me. No harm no foul. The glass is cheap to replace.
Old 10-20-2009, 04:30 PM   #5
Project10AE
Project10AE is on a distinguished road
use the great stuff in the blue can and dont put so much in and it will work much better... unless you want another show haha
Project10AE is offline   Reply With Quote
Old 10-20-2009, 05:51 PM   #6
BigIslandSevens
It was my fault that it blew up. I failed to clear the hole. I cleaned the housing out today and there really wasn't much foam in there. It was the gases that just made something give. Drivers side worked perfectly
Old 10-21-2009, 12:35 PM   #7
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I used that stuff when I was plugging up holes in my bonus room build above the garage. It keeps expanding for a long time. I had to come back an trim it the next day after it settled down.
Old 10-22-2009, 11:04 PM   #8
Jeezus
Jeezus is on a distinguished road
Is there anything for electric mirrors? I know there are 2 phillips screws under the mirror body. They are pretty tight as is and I wouldn't want to strip them. I can't tell what car is behind me because it shakes so bad!
Jeezus is offline   Reply With Quote
Old 10-23-2009, 04:22 AM   #9
BigIslandSevens
Hey Stu, I beleive that for the electric mirrors you use the process described by rx4ur7 above.^^
