Old 10-16-2009, 02:06 AM   #1
Ferarri V-12 Swap ideas, not a pipe dream.
So, I was thinking of good piston engines, and how a lot of people consider putting a "run of the mill" piston engine into the RX-7 as a disgrace.
Well, have I got a swap for you guys! It's a fact that a lot of rich people buy Ferrari cars. It's also a fact that a lot of the said rich people don't know how to drive, and therefore total the said Ferrari cars. This means that, while probably still quite expensive, and unobtanium for the average Joe, there are Good used Ferrari engines out there, specifically late model V-12 engines, some even come in a FR layout with a manual transmission.
Now, if one could legally get their hands on this setup, and if it fit in the FC3S at all, while still allowing room for a radiator, and other aux components, I feel like it would be one hell of a swap!
You could run the engine with a good standalone computer, ala MOTEC, fabricate custom exhaust if needed, get a custom drive shaft, engine mounts, and do a few other things, and bam, you have the only Ferrari powered Rx-7 in the world!
Now, in reality, this might not end up being as easy, right? (Barring getting an engine in the first place of course)
Old 10-16-2009, 07:28 AM   #2
I would think those kinds of engines would be in high demands...from Ferrari enthusiasts.
If you could wrestle one away, by all means, go for it.
The sound of the signing V12 is just euphoric.
Just the other day, I was tinkering with the idea of trying to fit a V10...probably BMW, since these come in 750's / 850's and a little easier to probably get?
All those BMW V10's noises I hear from Top Gear got me thinking...
hmmmmmm
Old 10-16-2009, 07:30 AM   #3
All the same concerns would have to be addressed as with any engine swap. Be it an LS, a boxer engine, a 13B-RE, or a Ferarri engine. Personally though......
However - I'm making more crank HP than some Ferarri engines so from a power perspective, not worth it. I'm not aware of any aftermarket companies making performance internals.
EVERYTHING would have to be fabricated because like you said, it's never been done before.
My biggest concern lies in the intake though. Most Ferarri engines are dry sumped and the intakes are monterous and tall. I think too tall for the FC.
Old 10-16-2009, 09:44 AM   #4
If a guy can fit a Jaguar V12 into a Miata, anything is possible.
http://jalopnik.com/398671/miata-own...-in-jaguar-v12
A BMW V10 would be awesome except for one thing. They are fairly new, and VERY expensive. The older 750/850's had V12 engines that ran individual computers for the left and right side of the engine. Talk about a PITA to make work properly. Compound that with the fact that the engines are pretty damn wide.
For reference, this is one in a box Caprice. Fills it out completely.
Old 10-16-2009, 12:25 PM   #5
Oops, brain fart.
You're right - 750's, 850's are V12's.
BMW V10's available in late model M5's and M6's - yack.
Old 10-16-2009, 01:07 PM   #6
Only thing about going with Euro engine is cost to service them (parts).. Well, at least that's what I hear... .and reason why most consider LS as its fairly cheap to obtain and get parts for.. Also fairly light.
I've also seen VERY nice LS1 FDs for only 18K.. Price has come down quite a bit.
Old 10-16-2009, 01:46 PM   #7
That is funny, because I would pay LESS for an LS1 FD than a stock FD.
Euro parts are not any more expensive than Honda, Toyota or Mazda parts. It is the labor from having to go to a 'specialist' for repairs.
*NEWS FLASH* It is just a fucking engine. Piston engines are all pretty much the same, plus or minus cylinders.
Old 10-16-2009, 02:21 PM   #8
+1 someone's project isn't as appealing, let alone with 0 rotary. if it goes up and down then it's like the other 99% of engines out there, only COOL thing is the NAME slapped on the block.
Older BMW parts are cheap so If you get an older engine you'd be ok, i guess. Nothing is ever ok with Ferrari....they hand make those engines....don't think the aftermarket sector is good for them....unless you like carbon fiber cupholders or cf aviator glasses or something fancy like that.
Old 10-16-2009, 02:38 PM   #9
I have a Ferrari necktie.
Fail
Old 10-16-2009, 11:12 PM   #10
The purpose of me posting this was NOT to talk about aftermarket potential, NOT about V12 vs LSx, and NOT for people to say that "it's not worth it"
Come on guys, I know all this already, what it takes, the consequences, the parts availability, etc etc etc. I just wanted to talk cars with people...
It is just an engine. Piston engines are all pretty much the same, plus or minus cylinders.
Well.... not really. how is a boxer flat 6 engine similar to a Chevy 350ci V-8 OTHER than both having similar pistons? The block is different, the heads are different, the "tuning" knowledge you need for both is WAY different. I love my 13B, but I also hold respect for certain piston powered engines, such as the K20A Honda engine, the Porsche/ Subaru boxer engines, the 2JZGTTE toyota supra engine, any V12 because its bad ass, and Ferrari V-8's because of how lovely they sound. A lot of piston engines are not all that great, but please remember that a 1.9L 4 cyl that came in the ford escort is nowhere in the same league as a Honda VTEC or Toyota 20Valve 4AGE, for example.
Old 10-17-2009, 08:46 AM   #11
Never said they are in the same league, however:
They all squish, bang, and blow.
If you know how an engine works on a mechanical level, then it is no harder to work on than any other car.
I have had a 1.9L Escort and a 2.2L VTEC. Not as different as you think.
Old 10-17-2009, 10:19 PM   #12
Lol DJ, so a wankel doesn't? It's still an internal cobustion engine.
Old 10-17-2009, 11:42 PM   #13
For my 2 cents I would say that an engine is an engine. What is cool for me is getting power out of that engine. Some engines make more specific power from the factory than others, but all engines can be modified. I can assure you that a guy with a machine shop and some know-how could make the 1.9 L escort stomp all over a stock 2.2 VTEC Honda.
Than someone could build the Honda engine, than the 1.9L gets a turbo... You get the idea.
What makes this swap cool is that it has not been done before. I have seen just about every Small block Chevy and Small block Ford in existence strapped into an RX7, but I have never seen a Ferrari V12 in person in anything. Therefore I would consider this a cool swap.
I heard of a guy converting an RX7 to rear engine and using a B20 Honda engine and transaxle mounted transversely. Do I think this was a good use of his time? No, considering that he took an engine that would make 200 WHp pretty easily out and replaced it with an engine that requires significant effort to make 200 flywheel Hp, plus the chassis was pretty badly compromised and the weight bias was destroyed. He did get unique points from me though.
There are some swaps that are just dumb, like putting a G10 (1.0L Geo Metro engine making 55HP) in an RX7. The Ferrari V12 swap has merit, because the car would still have class, character and poise, while obtaining a level of uniqueness that it didn't previously have.
Old 10-18-2009, 06:16 PM   #14
You'll rue the day you said that when gas goes to $5.00/gal and the G10 is getting 40mpg!
Really though, setting your car on fire would be a better option than a G10.
Old 10-18-2009, 10:58 PM   #15
Actually I wouldn't care at all, I have the G10 right where it belongs, in the Metro.
(It actually get around 55 mpg).
This is an old joke, because when the rotary in my '86 gave up the ghost, my friends were all talking about how at least the Metro ran, which made it way faster than the Mazda. This led to all sorts of 1.0L RX7 jokes, none of which seemed to care than my Metro had barely 100,000 miles on it and my '86 Mazda had almost 200,000 miles on it.
The fact that the '91 still ran fine and had 140,000 on it was also ignored, even when I brought it up.
