Old 03-13-2008, 01:20 PM   #1
3rd gen Alignment specs from Pettit Racing
Old 03-18-2008, 11:32 PM   #2
IR Performance
I ran those for a while. Tire wear was slightly accelerated but car handled awesome.
Old 03-19-2008, 06:45 AM   #3
SPICcnmFD
SPICcnmFD's Avatar
I think they are probably a good comprimise for steet and track driving, but I've got -2 degreees all around and I need more in the front for the track. The rear could use less probably -1.5 or -1.
1993 Rx-7 SM2 #11
At the local AutoX:
Speed for Sale shootout 2007:
A few laps at Barbers:
Old 03-19-2008, 08:22 AM   #4
This is what I got..
Decide to go more towards street..
FRONT
Camber: -0.3
Caster: 6.6
Toe: 0.03in
REAR
Camber: -1.2
Toe: 0.05in
Car rides OK with the Delrin Bushings, H&R, Koni Yellows, RB front sway, RB sway brace...
Old 03-19-2008, 10:04 AM   #5
Chadwick
Chadwick's Avatar
FRONT
Camber: -0.3
Caster: 6.6
Toe: 0.03in
REAR
Camber: -1.2
Toe: 0.05in
Phil, I would not run any tow on the street, toe is what wears out tires. With the small amount you’re running, it will make no real difference in handling anyway. Pettit's track settings are very conservative; I run -2.5 all the way around for camber, and around 3 caster. Too much caster will actually increase tire lift in corners. For Toe I run 0 front and .16" in on the rear. My setting are for track, not street use.
93 RX7 BB (Race Car)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Old 03-19-2008, 10:22 AM   #6
albertomg
For street and open track use, I run specs pretty close to those of the 16" wheels even though I'm running 17" wheels with 255/40/17. Running Konis with H&R springs.
Camber -1.5 front; - 1.2 rear
This wound up being more aggressive than I wanted but has been OK thus far. Someone on the other forum had apparently tested the Pettit settings with a pyrometer on track and said they worked well and provided proper tire temps. FYI - Having more rear camber than front camber increases understeer. The camber Phil listed above just about matches the specs on my Mini Cooper which is setup for lots of understeer from the factory.
Toe .06 degrees of toe in front and 0 in rear
For many cars driven on the street a little bit of "toe in" up front helps keep the steering from being darty when driving on the highway and trying to hold a straight line. I had mine at 0 front toe when I first got the car and didn't like it on street. It kept wanting to pull side to side driving down the highway. IIRC, more "toe in" in the rear helps the rear of the car rotate. Autox guys tend to use a decent amount of toe in in the rear.
Caster is now about 6 degrees
I experimented a bit with caster. When I got the car it had almost 7 degrees of caster. The steering had always felt heavier on this FD compared to my last one and after a year or so, I learned it was b/c I was running so much caster. While at the alignment shop, I was talking to the alignment guy and we decided to experiment with caster settings and we brought it down to 6 degrees. It made a world of difference. The steering feels much better and quicker. Now I understand why Rynberg always used to say "the FD doesn't need more than 6 degrees of caster".
Hope that is useful to someone.
Old 03-19-2008, 10:33 AM   #7
Chadwick
Chadwick's Avatar
More toe in in the rear helps the car power out of the corners better (keeps the back end planted), toe out would help it to rotate.
Dan
05 Silverado Z71
08 Mini Cooper
Old 03-19-2008, 10:59 AM   #8
Hey Dan,
Even if its only 0.03inch?? Its so minor
Also, what is Stock alignment from Mazda??
Old 03-19-2008, 11:04 AM   #9
Chadwick
Chadwick's Avatar
Hey Dan,
Not really enough to worry about, and like albertomg says, 0 toe will make the car track to the road conditions.
Dan
05 Silverado Z71
08 Mini Cooper
Old 03-19-2008, 11:11 AM   #10
Chadwick
Chadwick's Avatar
total toe-in 0.04 +- 0.16
Camber angle 0 deg
Caster angle 6 deg 40'
REAR:
total toe-in 0.08 +- 0.16
Camber angle -1 deg
Thrust angle 0deg +- 0.8 deg
05 Silverado Z71
08 Mini Cooper
Old 03-19-2008, 11:03 PM   #11
FD3S2005
FD3S2005 is on a distinguished road
what do you go to a place that does alignments and say i want this toe and this caster and yada yada?
FD3S2005 is offline   Reply With Quote
Old 03-19-2008, 11:16 PM   #12
Chadwick
Chadwick's Avatar
I do my own alignments and most shops will dial in what ever you want.
Dan
05 Silverado Z71
08 Mini Cooper
Old 03-20-2008, 01:06 PM   #13
dhays
dhays is on a distinguished road
Good thread. I'm really a noob, both with the FD and particularly with suspension and alignment. My FD is a weekend car with some auto-cross. I have yet to have the alignment checked since I bought it almost 4 months ago. It drives and handles better than I do at this point, but what settings would you folks recommend for my situation?
I have 18x8.5 wheels with 235/40/18 tires. As far as I know, the suspension is completely stock. I was thinking just using Pettit's short track specs as a compromise. Any ideas or suggestions?
Dave
dhays is offline   Reply With Quote
Old 03-20-2008, 02:55 PM   #14
Chadwick
Chadwick's Avatar
Short track settings would be pretty good for you, but I would make the front and rear camber equal.
Dan
05 Silverado Z71
08 Mini Cooper
Old 03-20-2008, 11:01 PM   #15
albertomg
I guess it would depend on how competitive you are at autox. Too much negative camber on the street isn't always a good thing.
