Old 09-07-2009, 09:37 AM   #1
fullspeedrx7
fullspeedrx7 is on a distinguished road
FD Irons on 13BT
can FD irons be used on an S4 or S5 13BT block?
fullspeedrx7 is offline   Reply With Quote
Old 09-07-2009, 09:57 AM   #2
moremazda
shookmotorsports.com
moremazda is on a distinguished road
Yup, but then it's no longer a S4 or S5 block. Effectively the plates are the block since they dictate the intake manifold.
moremazda is offline   Reply With Quote
Old 09-07-2009, 11:07 AM   #3
fullspeedrx7
so if i used the 13B-REW irons on a S4 13Bt rotating assembly, i'd have to use the 13B-REW LIM and UIM?
Old 09-07-2009, 06:57 PM   #4
Yup, and get the center plate machined to accept the FC motor mounts. Basically at that point you're doing an REW swap
Old 09-07-2009, 08:47 PM   #5
mazda_wes
mazda_wes is on a distinguished road
i recommend using stock housings if using stock irons. cosmo re swap is more fun anyways, from what i have been told.
mazda_wes is offline   Reply With Quote
Old 09-07-2009, 11:47 PM   #6
Short answer, NO.
The intake ports do NOT line up with the intake ports off the lower intake manifold.
FD engine mounts are located on the rear iron underneath.
The stock FC oil pan does allow use of them properly.
The FD front iron is shorter, so the stock FC oil pan does not line up properly.
Old 09-08-2009, 12:40 PM   #7
fullspeedrx7
thanks ted, and so basically for a stronger block w/o pinning, i should probably just get S5 irons and be done with it.
Old 09-08-2009, 01:29 PM   #8
That's my recommendation...
That's the easy route for building a stout 13BT that has proven to handle 400hp+.
