Old 09-05-2009, 01:19 AM   #1
Twilightoptics
Itchin' to Turbo
Twilightoptics's Avatar
Twilightoptics is on a distinguished road
Strange stock intake. Help ID
So I got this intake with another nikki carb from P71 a while ago.
I thought I'd dig it out and see if I could make something out of it.
It appears to have no provision for a shutter valve, and has 3 ports off the side the shutter valve would be on.
Would this be an upgrade from my stock '82 intake if I made a spacer to eliminate the port plate under my carb? Flow Characteristics?
I could run my manifold vacuum sources off the ports in this intake. I was thinking of welding the coolant passages shut to make it kind of a pseudo Racing Beat intake. I understand I need O-Rings if I do this?
Any ideas what this came off of?!
Twilightoptics is offline   Reply With Quote
