Old 08-21-2009, 02:41 PM   #1
JL1RX7
Speedo and Odometer not working
So go to drive home from work yesterday and the speedo and Odometer no longer working. Cable still hooked up in the back and into the tranny. Figured the cable must be broken so ordered a new one. Any other ideas or things I need to look at.
Old 08-21-2009, 04:34 PM   #2
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
Rotary_Rocket_87 is on a distinguished road
highly unlikely, but the speedo drive gear in the tranny might have sheared teeth off. usually the cable goes long before that but it is something else to consider.
'87 TII- full emissions removal, a/c removed, FPD removed, dual 12" e-fans, Rotary Performance FCD, ACT unsprung 6 puck w/ Xtreme PP, custom open 2.5 inch exhaust, custom clutch pivot ball, K&N cone filter, TB mod, RB downpipe, motor blown 8/7/09
'94 Mazda B4000- POS beater truck, stock
"The easiest way to fail is to never try." - Me
Rotary_Rocket_87 is offline   Reply With Quote
Old 08-21-2009, 05:11 PM   #3
Dzire
Dzire's Avatar
Dzire is on a distinguished road
I had a cable broke on me
RX8 2004 GT
RX7 1988 TII
Dzire is offline   Reply With Quote
Old 08-21-2009, 06:25 PM   #4
Probably fell off behind the cluster.
Old 08-21-2009, 06:25 PM   #5
JL1RX7
I figured the cable would be the one to go. It had made noise when it was cold back before I left in feburary. Now I just need to research how to change the cable out.
Old 08-21-2009, 10:02 PM   #6
its pretty easy you just have to take some of the dash apart.
Old 08-22-2009, 09:52 AM   #7
JL1RX7
Checked the back of the cluster and it felt like it was still connected. I ordered a new one and will replace it when it comes it. Went hunting in the FSM and didn't see anything on replacing it. But it looks like remove the cluster and feed it through the firewall and reconnect on the tranny. other than that can't think of anything else.
