Old 08-10-2009, 10:03 AM   #1
dreed7235
dreed7235 is on a distinguished road
cruise control
bought a car this weekend with aftermarket steering wheel. All of the cruise control stuff is under the hood just nothing inside. Any ideas on where I would put the controls and what I could use? I just drove the car 9 hours and it was a pain in the ass.
dreed7235 is offline   Reply With Quote
Old 08-10-2009, 02:22 PM   #2
Signal 2
Viable Fossil
Signal 2's Avatar
The easiest solution might be to replace the aftermarket wheel with OEM. If it's from an Touring model it would likely come with the button controls. That way if the previous owner didn't cut the wires, it would be a simple plug and play.
Be aware that in addition to the steering wheel buttons, the on/off switch on the dash, and the actuator under the hood, there is also a cruise module located behind the driver's side kick panel.
Jim
VR R1 FD
Old 08-23-2009, 09:06 PM   #3
Lilfreddie
Lilfreddie is on a distinguished road
cruise help
i wired the factory buttons from the steering wheel under the steering column and wired it directly to the wires under the column, also solder a regular 194 light bulb to the original air bag wiring to eliminate your air bag light! call me if you need more help 9858560916
Lilfreddie is offline   Reply With Quote
Old 08-25-2009, 11:32 AM   #4
proz07
Needing a new tow rig.
proz07's Avatar
does the light illuminate? if so ill have to find a resistor equivalent... heres my CC buttons setup but m cable is cut. so anyone wanting to sell a CC cable ill take it.
z
