Old 08-07-2009, 12:17 PM   #1
FC3S Murray
frustrated!
FC3S Murray's Avatar
EGT temperature ranges??
I just purchased two EGT probes and gauges for my new set-up. I am curious to what some of the "Average" EGT's our produced by turbo rotaries?
Basically I am looking for a common: good/bad/stable temp ranges.
Kind of vague but thanks.
Same pig, new soul
Old 08-07-2009, 02:26 PM   #2
http://fc3spro.com/TECH/MODS/EL/GAUGES/egt.htm
Old 08-07-2009, 06:31 PM   #3
FC3S Murray
frustrated!
Thanks Ted.
Does sensor position matter in regards to being up or down due to possible contamients(sort of like a wideband)?
Same pig, new soul
Old 08-07-2009, 10:36 PM   #4
No, since it's most likely a shielded thermocouple.
The only thing that'll damage it is debris - if you have crap flying in the exhaust, there's other things that you should worry about instead of the probe being damaged.
Old 08-08-2009, 07:29 AM   #5
FC3S Murray
frustrated!
haha, good point. I was thinking along the lines of moisture buildup, ect. Since it is shielded then never mind. Thanks again.
Same pig, new soul
Old 10-11-2009, 07:11 AM   #6
Barry Bordes
Barry Bordes's Avatar
Mine just keep on rising. Up to almost 1000 deg C at 8000 rpm on some runs.
Barry
Old 10-11-2009, 07:35 AM   #7
If you were running NA, I would recommend more ignition timing.
Is this pre-turbo or post-turbo?
Old 10-11-2009, 08:04 AM   #8
Barry Bordes
Preturbo, 2" from the port.
Barry
GOD the Incomprehensible Obvious (www.frksj.org)
Old 10-11-2009, 12:39 PM   #9
1000 C pre-turbo is not abnormally high for any turbo engine at 17 psi boost, I actually would have expected higher (there are diesels making more than that).
(The continuous temperature increase is probably from several factors, heating of the rotor/housing surface, increased turbine back pressure, and less time to burn the fuel in the chamber at higher revs.)
Old 10-11-2009, 12:44 PM   #10
just thought i would toss this out there
Old 10-12-2009, 02:08 PM   #11
mazdamaniac
mazdamaniac's Avatar
mazdamaniac is on a distinguished road
Some of the info on that page is incorrect or misleading.
First, it is correct that the EGT numbers are meaningless without finding mean best torque on your particular motor first. This will give you an idea of what the EGTs should be under ideal conditions and full load.
After that, the relationship between timing and EGT and AFR and EGT gets cloudy.
Advancing the timing will only lower EGTs if the actual combustion event is already late (i.e. - peak pressure happening after 20° ATDC or so).
If the peak pressure is early (detonation, which may NOT be audible), advancing the timing will makg the EGTs go up.
If you have found the MBT AFR reading, making the mix leaner will raise the EGTs to a point, but then they will start to go down again once you start to lean misfire (which may NOT be audible or even noticible in normal driving).
Making the mix richer may lower EGTs, but only to a point.
Once you start to get rich misfires, the EGT will start to climb quite suddenly and any fuel that doesn't meet O2 in the combustion chamber might cause manifold combustion which will do CARAZY things to the EGT (up, down, fluctuating, who knows).
All that said, 1800°F - 2000°F right at the ports on a boosted rotary application is not too unusual.
mazdamaniac is offline   Reply With Quote
Old 10-16-2009, 07:40 AM   #12
Brandon?
"Mean Best Torque" is easy enough to figure out - i.e. dyno.
How you figure "peak pressure'?
I assume you're talking about BMEP...
This kinda merasuring / monitoring is above what most of us can attain.
We're talking big range pressure transducers plumbed into the engine - do you really wanna drill holes into your engine???
I don't see how my page is "incorrect or misleading"?
What I wrote general supports what you just said?
Old 10-17-2009, 08:36 AM   #13
Brandon?
Ted, I think I can help.
Peak torque is found where the peak chamber pressure is attained at ~12 degrees ATDC. This is a function of fueling and ignition timing at a specific engine speed.
Most EGT writeups mention peak torque (ignition timing wise) as being the low point in the EGT map. This is primarily true (with a few far-reaching exceptions).
As you said, peak torque timing is obtainable on a dyno. However, most people who tune using EGT are doing so because they are not tuning on a dyno. Also, many people do not have enough nerve to advance the timing until power starts falling off so they don't know if they actually found the peak of the curve.
As to your writeup, I think this is what he takes exception to:
Going leaner than best power will raise EGT - the dyno should also
show the engine LOSING POWER. This is due to inaudible detonation. If we go
leaner, EGT will start to skyrocket and detonation is pretty evident. From best
power, if with richen it up, the EGT will actually go DOWN for slightly richer
conditions. You still get almost complete combustion, but the extra fuel cools
everything down. If we richen it up substantially, it'll come to a point where
all the extra fuel will start to ignite out the exhaust port, and this will cause
the EGT to rise (this looks exactly like lean!) and sound like detonation, because
the excess fuel is igniting in the exhaust system; this is when too rich will also
raise EGT.
If you research this carefully, you will find that the higher EGTs from lean combustion is due to the slower burn rate of a lean charge (later burn = lower expansion ratio). You should NEVER see this condition with a turbocharged car on the dyno. In fact, the chances of the ignition system being able to light a high-pressure lean charge are not very high. You will see it if you run a lean cruise in vacuum (lean of 15:1).
With a turbocharger, the time when the EGTs start to rise is the point where all the fuel is being burned. This will be significantly rich of peak power. The unburnt fuel cools the combustion charge as it absorbs some of the combustion heat to vaporize. Very few people tune turbocharged engines to run lean enough to make peak power on the dyno (13.0-13.5:1).
I have not found any information on the rich side (rich misfiring) in any books. Your explanation makes good sense (as long as there is additional oxygen in the exhaust that allows combustion to occur).
I think your write-up is very good, it explains the variability of the sensors very well, gives good base ranges, discribes sensor behavior accurately and contains no mis-information that would cause someone to destroy an engine.
There are several awesome books that address EGT ranges and behaviors on engines. Most of what I put above comes from the Bosch automotive handbook, but I read almost identical information in "Automotive engines and Air pollution".
Your numbers and ranges are correct, but the explanations for the observed behavior are confusing and possible mis-informed.
I am probably a little to strict about data accuracy, as the write-up would not cause harm as it is.
Many thanks for providing the resources.
