Old 08-04-2009, 08:48 PM   #1
shadow102
shadow102's Avatar
shadow102 is on a distinguished road
rewire fogs, headlight motors, and high beams
I am currently replacing all the bulbs in my car with HID's and wanted to change some stuff around. This is all on a s5 vert btw
first off my highbeams haven't worked since I bought the car, if I pull on the light stalk with the headlights off it will flash them but only the low beams, however with the lights on I pull the stalk and nothing happens. Do the high beams use a seperate fuse or a relay or is this a common problem that is fixed else where? The bulbs are brand new so that's not the issue
Secondly I want to wire it so I can turn my fog lights on without having to turn on my headlights even if I have to turn on my parking lights that's ok just want fogs without headlights...any wiring suggestions I would appreciate it.
Lastly and not highly important but I want to know if its possible to rewire the headlight switch where when I turn the headlights on the headlight motor switch will still allow me to flip them down and direct them through the ftp's.
Thanks in advance for all the help.
shadow102 is offline   Reply With Quote
