Old 07-30-2009, 04:20 PM   #1
Justen
In Too Deep
Justen's Avatar
Need help! Fresh Rebuild Wont Turn Over
I just finished hooking everything back up after a rebuild on my 90 TII, now streetported, walbro pump, emissions removed, warmup selonoid/box removed, rats nest gone, but i kept the oil metering pump. Filled the oil and put some coolant in it. Tried to start it yesterday, and the starter wouldnt turn the motor over. Tried a couple times and my warning buzzer went off. I used a jumper pack for the battery to make sure i had enough juice. I DO HAVE SPARK. Went underneath the car and the starter was hot, so i had it checked at Advance. it failed so i bought a new one. Put the new stater in today and it does the same damn thing as it did yesterday...
Is there any part of the start-up procedure i'm missing?
Do i need to fool the ecu or anything?
Any connectors for emissions that should be left on or grounded?
..i havent hooked up the ABS yet
Ideas?
