Old 07-20-2009, 05:26 PM   #1
RandyRhoads
RandyRhoads's Avatar
RandyRhoads is on a distinguished road
Car won't start
Ok so I have an 87' N/A, and over the weekend I dedicated my time to change out the clutch. After all that was said and done the clutch and transmission was on, and everything was hooked back up, I had changed my battery cable teminals. The next day I went out to start it up and nothing. I had then found out that I put the battery in backwards lol (it was dark out when I put it in). I switched it up and tried to start it and the starter makes this loud ass noise I have never heard before. It just makes a loud winding sound. I have no clue to what it is. Can anyone help me out maybe tell me why it's doing that???
RandyRhoads is offline   Reply With Quote
Old 07-20-2009, 06:00 PM   #2
FCTII
FCTII is on a distinguished road
possibly fried the starter by hooking them up backwards.
FCTII is offline   Reply With Quote
Old 07-20-2009, 06:33 PM   #3
RandyRhoads
I was thinking about that but would the starter even work after it had fried???
Old 07-20-2009, 07:03 PM   #4
The starter motor itself would work. The solenoid is probably trashed, so you need a new starter.
Funny, a friend of mine hooked his FC up backwards, and just blew the main fusible link.
Old 07-20-2009, 07:10 PM   #5
parrotfever
parrotfever's Avatar
parrotfever is on a distinguished road
[QUOTE=djmtsu;92478]The solenoid is probably trashed, so you need a new starter.QUOTE]
I'd agree. Hopefully that's the worst of it but I'd be more concerned about the ECU.
parrotfever Bob
1989 RX-7 convertible
2000 F-350 4x4 crew cab
2002 Altima 3.5
wife's buggy - 2004 Titan 4x4 crew cab
parrotfever is offline   Reply With Quote
Old 07-21-2009, 04:33 PM   #6
RandyRhoads
How would I know if it's the ECU or the main fusible link???
Old 07-21-2009, 04:44 PM   #7
All the major fuse links are on the fuse holder bolted to the drivers side strut tower. When you pop the cover off, they fuse links have clear tops, so you can clearly see if they are toast.
As far as the ECU, try running a diagnostic and see what codes it throws.
Old 07-21-2009, 05:50 PM   #8
RandyRhoads
Right on guys thanks alot
Old 08-04-2009, 12:11 AM   #9
hhn2002
hhn2002 is on a distinguished road
haha its always either someone is drunk or its late at night.
hhn2002 is offline   Reply With Quote
