Old 07-12-2009, 08:46 PM   #1
project86
Can't.Make.Up.My.Mind.
project86's Avatar
cleaning!!!
hey guys. so im gettin ready to park the 7 so i can really give it some good work. i want to do EXTENSIVE cleaning underneath the car as far as the rear end and stuff. so im just curious if there is a good way of cleanin all that stuff besides the general soap and water. Thanks im lookin forward to a good time rebuildin!
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 07-12-2009, 08:49 PM   #2
Get a good degreaser... I like SimpleGreen personally.. let it soak on there for a while and use a nice pressure washer to cut through the grime....
Old 07-12-2009, 11:12 PM   #3
project86
project86's Avatar
ok. ill keep that in mind. its gonna be really nice to go through all that stuff and have clean things . i dont think its been clean since 86!
'90 GTUs
'10 Toyota Prius
Old 07-13-2009, 12:22 AM   #4
mazdadude7
mazdadude7's Avatar
mazdadude7 is on a distinguished road
just pull it all apart and put a urathane bushing kit on and clean it while its apart! and when your working on it you can curse at me for the idea.
mazdadude7 is offline   Reply With Quote
Old 07-13-2009, 02:45 AM   #5
Boostmaniac
I like how this man thinks.
Old 07-13-2009, 06:07 AM   #6
Simple Green + scotch brite + toothbrush + goggles + particulate mask + creeper + lots of swearing = clean undercarriage.
Or, do like we did with my buddies TII. Strip ot down completely and put it on a rotisserie
Old 07-13-2009, 04:44 PM   #7
project86
project86's Avatar
hahah you read my mind about the bushings... they are waitin patiently in the box
'90 GTUs
'10 Toyota Prius
Old 07-13-2009, 05:11 PM   #8
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I want to do that so bad. Ever since my first FC, I'm super paranoid about underbody rust, but from what I hear applying undercoating overhead is a PITA. I'd imagine doing it on a rotisserie would be a breeze though.
Old 07-13-2009, 07:17 PM   #9
project86
project86's Avatar
im planning on putting in black interior so it will be all stripped out anyway. ill just clean it the best i can with it on jack stands
'90 GTUs
'10 Toyota Prius
Old 07-13-2009, 07:50 PM   #10
Interior is probably the lightest of all the parts that need to be stripped. The entire car should be down to a bare chassis as in not one single nut, bolt or even wire is left. That's how we did it anyway.
It's FILTHY. And that shit gets EVERYWHERE. We used a shutz gun so applying it by roller would probably be a little "neater" but still. Tape off EVERYTHING that you don't want that crap on and I mean EVERYTHING. We used painters tape and it still got underneath it. I hate it, but yet I can't wait to get my car on that same rotisserie this winter and do the same thing...... and treat a little cancer while I'm at it too.
Old 07-13-2009, 08:45 PM   #11
project86
project86's Avatar
oh cancer.... thats not fun. in the few spots i have repaired its not really hard its just a pain in the ass. i really do plan on strippin the whole chasis down. i want to see EVERYTHING and know that i can get everything new
'90 GTUs
'10 Toyota Prius
Old 07-13-2009, 08:49 PM   #12
project86
project86's Avatar
9
'90 GTUs
'10 Toyota Prius
Old 08-14-2009, 05:05 PM   #13
FC_fan
FC_fan is on a distinguished road
I wish I had access to a rotiserie. I've got to do some major side frame/inner rocker repair to do. lots of de-rustification and bracing panels as well a couple small replacement patches. then I have to make some new outer rockers. I'm planning on cleaning and coating the entire underside with metal ready and POR-15. doing that to most of the rest of the car to, getting it close to bare chasis.
BTW guys, if you are using POR-15 over large painted sections, industrial paint stripper is your friend. POR-15 only bonds and prevents rust when it is in direct contact with metal. POR-15 is the best stuff I've ever used for rust prevention so check it out.
FC_fan is offline   Reply With Quote
Old 08-14-2009, 11:12 PM   #14
we built ours out of 4x4's and welded together some 1/4" brackets to mount it to the bumper supports.... actually my friend built the wood stuff and I welded the brackets. Either way it wasn't that hard at all.
Old 08-14-2009, 11:22 PM   #15
FC_fan
so the whole thing was made out of wood and that supported all that weight! wow, you have any pics of it. also what kind of wood did you use, I know they were 4x4's but any details?
that is awesome that he did that and it worked. I need pics to see if I can do the same thing, would be so much easier and probably take half the time to finish the project. help a follow rotor head out!
