Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 06-30-2009, 05:14 PM   #1
Garfinkles Motor Works
New style hard nylon motor mounts
This design features no metal to metal contact.
Old 06-30-2009, 05:17 PM   #2
More pictures of motor mounts
Shows the finish product. Can be cut to the length needed as used with the garfinkle oil pan brace.
Old 02-23-2010, 12:27 PM   #3
AchillesGr
AchillesGr is on a distinguished road
hi ,
how much is it costs?
how i install them? do you have any webpage to take a look?
thank!
AchillesGr is offline   Reply With Quote
Old 02-24-2010, 03:07 PM   #4
The cost is $200 shipped in the USA .I will need to get your old set in exchange .They install as the stock ones after you drill the frame hole out to 1/2 inch .I use a 1/2 inch grade 8 allen fine threaded bolt and self locking nut with it for more strengh .It is easy to drill the holes from the bottom .I do not have a webpage .The mounts can be made 3/16 inch shorter if you are using my oil pan brace,then the motor will sit at the stock height. Thanks David
Old 02-24-2010, 03:28 PM   #5
dudemaaan
dudemaaan's Avatar
looks nice man
Old 04-23-2010, 07:39 AM   #6
To those who have bought motor mounts and not sent back the old stock cores please do so to complete the deal ,thanks .
Old 06-09-2010, 03:30 AM   #7
goracer
goracer is on a distinguished road
I don't want to be rude or out of line but are these less likely to melt or crack and crumble from the heat like the red versions I bought years back (in a group buy from another vendor)?
goracer is offline   Reply With Quote
Old 06-09-2010, 07:43 AM   #8
I was told they will resist the heat when I bought the materal. Maybe they lied,as with any of my things if it fails in a unreasonable time get your money back when you return the part.
Old 06-09-2010, 09:18 AM   #9
goracer, glad you found the link
Garfinkle is a stand up guy and all his parts are well thought of. I don't think you'll have any issues with his products... also just as he stated, he will give your money back if it fails.
Old 06-09-2010, 09:55 AM   #10
Kentetsu
Kentetsu's Avatar
Very nice. Are these for 2nd gen? or 3rd gen? (sorry for the stupid question, probably obvious to everyone else)
Old 06-09-2010, 07:45 PM   #11
third gen
Old 06-18-2010, 09:19 PM   #12
OverRev
OverRev is on a distinguished road
David, how is ur nylon mount compare to polyurethane mount and the factory rubber mount? is it harder or softer?
OverRev is offline   Reply With Quote
Old 06-19-2010, 10:55 AM   #13
Hard compared to factory .
garfinkles motor works, motor mounts
