Old 06-30-2009, 08:23 AM   #1
ProjectD
ProjectD is on a distinguished road
Parting out engine and trans LOTs of aftermarket and stock parts!
Polished UIM $150
Greddy 2 row FMIC w/ HKS SSQ BOV $900
Defi mechanical Boost gauge $130
HKS EVC IV electronic boost controller $150
Single turbo engine harness with FJO injector driver (low miles) $500
Aspec GT3574 turbo .96 A/R $600
Tial 46mm WG $300
Ported rx7store singleturbo manifold with tial 46mm wg flange $150
NEW air intake temp sensor $40
Bosch 1680cc injectors cleaned and flow tested (5) $ 70 each
Lucas/RC 120lb injectors (1 pair) $90
Fluidyne Radiator w/ stock fan setup $350
FC leading ignition coil (3) $50 each
5 speed tranny w/ gotham short shifter no grinds $400
Supra TT Fuel pump(s) 2 $140 shipped (each)
Big Boy fuel setup (black anodized top feed rails, sard FPR w/gauge and mounting bracket w/ harware. 2 edlebrock 40 micron stainless replaceable stainless steel fuel filters, All lines and fittings required for install. hose is black nylon with SS reinforced braid. This fuel setup will handle whatever you wanna run though it from pumpgas to race gas and even E85. $590
Still have more things to list so check back
ProjectD is offline   Reply With Quote
Old 06-30-2009, 11:51 PM   #2
Rotary Inspired
Rotary Inspired is on a distinguished road
Cyan what are you doing with the car LS1? Interested in your turbo
If you wanna become ASE certified buy the RX7.
Rotary Inspired is offline   Reply With Quote
Old 07-01-2009, 08:08 AM   #3
ProjectD
Yes something along those lines...
I'll update this thread with pics as well as more parts.
Old 07-01-2009, 08:14 AM   #4
ProjectD
Polished UIM $150
Greddy 2 row FMIC w/ HKS SSQ BOV $700
Single turbo engine harness with FJO injector driver (low miles) $400
Aspec GT3574 turbo .96 A/R $550
Tial 46mm WG $250
Ported rx7store single turbo manifold with tial 46mm wg flange $150
Bosch 1680cc injectors cleaned and flow tested (5) $ 65each
Lucas/RC 120lb injectors (1 pair) $80
Fluidyne Radiator w/ stock fan setup $275
FC leading ignition coil (3) $40 each
5 speed tranny no grinds $300
Big Boy fuel setup (black anodized top feed rails, sard FPR w/gauge and mounting bracket w/ harware. 2 edlebrock 40 micron stainless replaceable stainless steel fuel filters, All lines and fittings required for install. hose is black nylon with SS reinforced braid. This fuel setup will handle whatever you wanna run though it from pumpgas to race gas and even E85. $500 (i'll even throw in a pair of1680cc injectors
Also willing to part out the fuel system...
Supra TT Fuel pump(s) 2 $140 shipped each
Ebay Engine torque damper painted black $50
Thermostat housing with AST delete $50
Throttle body $65
LIM $50
Gotham racing Short shifter $145
BDC ported half bridge REW $2000
Gotham racing polyurathane motor mounts $100
Old 07-01-2009, 08:15 AM   #5
ProjectD
Old 07-01-2009, 08:16 AM   #6
ProjectD
Old 07-01-2009, 08:18 AM   #7
ProjectD
Old 07-01-2009, 08:36 AM   #8
ZGN
Administrator
ZGN's Avatar
I am interested in the FMIC can you post photos of it?
How many miles... track/dragstrip events on the transmission?
Kevin
Old 07-01-2009, 08:54 AM   #9
ProjectD
I'll go get some pix of the FMIC now, transmission was rebuilt before I bought the car and I have put about 30-40k miles on it, about 8 trips down the drag strip (never power shifted) and no track days. I've used royal purple synthetic fluid as long as i've had it
Old 07-01-2009, 09:30 AM   #10
ProjectD
Old 07-02-2009, 12:24 PM   #11
ProjectD
New pix: Fluidyne and Ebay torque brace
Old 07-03-2009, 11:34 AM   #12
ProjectD
Arrow Update!
Polished UIM $150
Ebay Engine torque damper painted black $50 needs respayed
Throttle body $65
LIM $50
Aspec GT3574 turbo .96 A/R Deposit Received Pending
Tial 46mm WG Deposit Received Pending
Ported rx7store single turbo manifold with tial 46mm wg flange Deposit Received Pending
Down pipe for single setup Deposit Received Pending
Old 07-03-2009, 04:05 PM   #13
ProjectD
Single turbo engine harness with FJO injector driver (low miles) SOLD
Fluidyne w/ stock fan setup SOLD
Old 07-05-2009, 03:00 AM   #14
ProjectD
Big boy foy fuel system and one pair of 1680cc injectors SOLD
Still have 3 1680cc injectors left, as well as 201200cc
Old 07-07-2009, 08:34 AM   #15
ProjectD
Polished UIM $150
Bosch 1680cc injectors cleaned and flow tested (3) $65 each
Thermostat housing Regular $40
Throttle body with TPS $65
LIM $50
FD trailing Coils about 15k miles on them $55 each
Midpipe $150
Greddy PE catback $300
Driveshaft $100
PPF $100
Fuse block with batter cable $65
Engine pressure tester $30
Pineable exhaust porting template $20 shipped
If you see something you like Make me a offer. Some prices are OBO!
