Old 06-20-2009, 10:06 PM   #1
prrex4ever
prrex4ever's Avatar
Cusco rear triangle bars.
I got a set of Cusco triangle bars from Mike at Shp.com here in the vendor's section to match the rear Cusco OS type strut bar I got as a father's day present but while doing some trial fitting they seem to be too long in other words they overlap the center mount. Does anybody have any input on mounting these. I appreciate any input before I start drilling holes in the floor of my FD. Thanks in advance and BTW Mike at Shp.com is a GREAT seller.
Old 06-26-2009, 01:08 PM   #2
SHPmainMAN
SHP Motorsports
SHPmainMAN's Avatar
SHPmainMAN is on a distinguished road
Thanks for the compliment man, let me see if i can find anything for you regarding this install.
Mike
SHPmainMAN is offline   Reply With Quote
Old 06-26-2009, 06:58 PM   #3
prrex4ever
prrex4ever's Avatar
Thanks Mike and your welcome. I found some pics and some hints from someone on the "other" site. I'm going on vacations tomorrow and hope to install them when I get back. Any input is much appreciated.
Old 10-11-2009, 04:10 AM   #4
kyleaudio
kyleaudio's Avatar
kyleaudio is on a distinguished road
i dont have it for my FD, but i do have the OS-T for my FC and it went in fine, make sure that you dont have the kit for the FC, that could explain the longer arms. when you do install them tho, dont over tighten the bolts that go through the floor that are welded to the plate, the metal isnt very hard, i twisted one of them off and had to drill it out and use a bolt.
-kyle
kyleaudio is offline   Reply With Quote
