Old 03-10-2008, 04:04 PM   #1
warwickben
sa rat rod
ball joints help asap.
hey guys i need some help. i have to replace my ball joints on my 1980. i got new ones shiped to me and i got them today. i know your not spose to reuse the lower control arms. but you are not able to buy new one. on th evil site every one said just add a few tack weld's which will not be a problem for me. how can i get the old ball joints out. i dont think i can do it my self. but what type of place can i go and have them pressed out and the new ones pressed it?
Old 03-10-2008, 08:58 PM   #2
Kentetsu
Kentetsu's Avatar
I used Autozone's loan a tool program, and borrowed their ball joint press set. Work carefully, making sure everything is lined up properly, and you might be able to do it. I had no problem doing mine, and they were tight enough that I didn't have to add welds or anything. Just make sure that you don't deform the arms when pressing the joints...
Old 03-11-2008, 03:54 AM   #3
warwickben
sa rat rod
how does that tool loan program work.
Old 03-11-2008, 12:01 PM   #4
blwnrtr93
blwnrtr93's Avatar
for the tool loan program essentially what you are doing is buying whatever tool you are borrowing for a more expensive amount than it usually sells for and then when you return it they return your deposit. it works pretty well. i used it to borrow a tap and die set to fix some fouled up thread on my exhaust studs.
1993 BB RX-7
2005 Black Mazda 6i
1991 Primer Celica GT
1968 Camo Chevy P/U
Old 03-11-2008, 02:57 PM   #5
warwickben
sa rat rod
i found this a ball joint press from harbor freight for like 30 bucks. i could just sell it on ebay when done.
Old 03-11-2008, 06:34 PM   #6
Kentetsu
Kentetsu's Avatar
How is that easier than the loan a tool program?
Old 03-11-2008, 06:38 PM   #7
Not sure....Plus harbor freight stuff is usually of questionable quality.
Old 03-11-2008, 07:19 PM   #8
warwickben
sa rat rod
true. wounder if i can do it in the store and not pay any thing lol . iam friendly with a few guy's at the store down the street from my house.
also guys can you look at my e-fan thread and tell me what you think.
Old 03-12-2008, 02:19 AM   #9
blwnrtr93
blwnrtr93's Avatar
it can't hurt to try going to the store with the lower control arms and pressing the ball joints out while at the store. i didn't even know the guy at my local store and he asked if i wanted to use the tools in the store.
1993 BB RX-7
2005 Black Mazda 6i
1968 Camo Chevy P/U
Old 03-13-2008, 08:33 AM   #10
$100T2
Big Daddy
$100T2's Avatar
I've never heard "don't re-use the control arms" before. Just press them out. You go to autozone and get the front end service kit... They charge you (I think about) $120 for it, which they return when you bring it back. Just mix and match the pieces until you find the right combination to get them out... I did it on mine, it's not hard at all.
Old 03-13-2008, 09:59 AM   #11
warwickben
sa rat rod
in the fsm it says not to reuse the lower control arms . since you not able to buy oem one any more just the racing beat ones. i was told to just put 3 1cm welds on them to make sure they dont come out. i figure by the time iam ready to replace my ball joints again ill drop the money and get the racing beat control arms.
Old 04-15-2008, 09:38 PM   #12
Scott1982RX7
Scott1982RX7's Avatar
Scott1982RX7 is on a distinguished road
I can tell you from personal experience that the ball joints can come out when pressed back into the original arms. That being said, a little tack weld would be all that is needed to correct the problem! And you can buy new arms - I did. If I had it to do over, I would have bought the rack and pinion system that includes new arms
Scott
1982 RX7 - 143K (3rd of this gen)
1995 BMW 525 125K
Scott1982RX7 is offline   Reply With Quote
Old 04-16-2008, 07:56 AM   #13
bwaits
Talk - Action = Nothing
bwaits is on a distinguished road
Its a known deal.
The problem is that the control arm material is thin in this area. The operation of pressing them in from the factory expanded a smaller hole to snug them in. The operation of pressing the old joints out usually distorts the metal.
New ball joints do not get enough "bite" to stay in since the hole is already expanded from the factory and distorted from you pressing them out.
Some aftermarket ball joints have a groove machined into them for a c clip to keep them in. If yours do not you will want a few small tack welds. Mig is the best since you can get in and get out without heating up the ball joint to bad. Tig concentrates to much heat and can burn up all the grease.
-billy
bwaits is offline   Reply With Quote
Old 04-16-2008, 09:50 AM   #14
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
For everyone's information, those with the C-clip were the Moog brand and are no longer in production.
I got some of the last ones from rock auto.
impulsive-RX7 is offline   Reply With Quote
Old 04-20-2008, 08:51 AM   #15
Scott1982RX7
Mazdatrix still sells control arms (oops can I mention their name, oh wait, that is the other board).
They are about 150 each.
Scott
1995 BMW 525 125K
