Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > RHD Japan
RHD Japan www.rhdjapan.com (Japan) Japanese OEM/aftermarket part exporter
Old 06-14-2009, 07:00 PM   #1
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
FC3S: SuperNow vs GT-1 motorsports front hubs
I heard from a friend's friend who lives in Japan that the SuperNow hubs are setup to have serviceable bearings. Are the GT-1 Motorsports hubs the same way? Also, it looks as if the front studs are longer and I wonder if you guys know the lengths of the studs. The last thing I'm curious of is if you guys know the weights of these hubs vs the stock aluminum ones.
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
Old 08-26-2009, 04:47 AM   #2
RHDJapan
RHDJapan is on a distinguished road
KSP Attain actually supply the hubs to GT-1 and they have the options of either including OEM bearing to their hubs or with out. so the bearing are indeed serviceable as well.
The studs that come with the hubs are the same length as stock, but they can be removed and longer studs installed. The longer studs can either be 10mm or 20mm longer.
I would imagine the hubs are heavier then stock as they are made out of steel as opposed to the stock aluminum ones.
RHDJapan is offline   Reply With Quote
