Old 06-10-2009, 06:23 PM   #1
bbade
bbade's Avatar
bbade is on a distinguished road
Angry 1993 Glovebox
I just want to say that Mazda really dropped the ball on this one. Turns out they made it absolutely impossible to repair if the inner latch mechanism breaks.
The mechanism screws to the inner liner and then the outer faceplate gets plastic welded to the inner liner making the screws and mounting points for the latch completely inaccessible.
On that note if anyone has found a way to repair their glovebox please enlighten me.
Proud owner of a base 1993 Montego Blue FD.
PFC, RB single tip, Koyo Radiator, KDR rebuilt motor, polished OEM front strut bar, FEED replica sideskirts, OEM 99 spec rear spoiler, SuperPro Bushings
Many thanks to Dave at KDR for sparking my rotor addiction.
bbade is offline   Reply With Quote
Old 06-10-2009, 08:06 PM   #2
Garfinkles Motor Works
I repaired the hinge for the pull part .If I remember I used a soildering iron and reformed the pivit hole .Now I open it with care .The profect B insurance papers are in there.This was 4-5 years ago .
Old 06-10-2009, 10:00 PM   #3
bbade
bbade's Avatar
I wish the pull part broke, but it was actually the inner part, the actual latch. I now found out it had broken before and the owner somewhat fixed it using plastic glue which explains why there was a large section of inner lining removed. Anyway it is completely inaccessible to work on, I find it pretty irritating to be honest.
Old 06-10-2009, 10:00 PM   #4
prrex4ever
prrex4ever's Avatar
I just used a small piece of velcro to keep mine closed. Worked for me, I'm just lazy plus it's empty anyway.
Old 06-13-2009, 10:59 AM   #5
Caim
Caim's Avatar
Caim is on a distinguished road
I have been looking into this myself as mine broke about 6 months ago. I have called ray at mazda and he looked at it. The weird thing is they sell both the inner and out latch part for 80 bucks. But there is no way to get the inner part out unless you "unweld" it. So i would say that there is a way, but it means that you have to "unweld" those parts and then redo them when you are all done. But, being that i have been short on time, and also money. I just zipties it up. That is until i can fix it right hahaha.
Caim is offline   Reply With Quote
Old 06-14-2009, 11:16 AM   #6
duval7
duval7's Avatar
duval7 is on a distinguished road
i thought i was the only one that had this problem. i am doing a complete over haul on the car so i haven't gotten to think about how to fix it yet. so hopefully one of you guys can figure it out. we seem to have alot of issues with the glovebox on these cars.
duval7 is offline   Reply With Quote
Old 06-15-2009, 10:53 AM   #7
bbade
bbade's Avatar
I spoke with Ray at Malloy and was quoted about $300 for the glovebox assembly. The only solution I have come up with would be to recreate a portion of the inner shell out of aluminum. This new piece would have the latch assembly attached to it and in turn would be attached to the outer and inner shells. I highly doubt that it would be possible to attach the inner and outer shells like stock if you broke the original "welds."
I am hoping to find a used glovebox as it will be a much cleaner install. On that note, if anyone has a 1993 glovebox for sale I will gladly take it off your hands.
Old 06-15-2009, 05:28 PM   #8
cewrx7r1
The Judge
I was the first to have a glove box latch failure back around 1995. The internal screws loosen and one fell out. I had to use a hacksaw blade to cut through the metal latch hoop because the latch would not unlatch. Had that welded back together.
Used a Dremel cutting tool to cut out the latch, about a 3" x3" square. Put the screws back in with epoxy and expoxied the cut out piece back in. It has been working perfectly for 14 years now.
You have to use your imagination and mechanical skills if you want to own a FD!
Old 06-15-2009, 06:50 PM   #9
bbade
bbade's Avatar
A previous owner hacked out a section of my glovebox to repair the latch. In the process they managed to snap both plastic mounting points, they attempted to glue everything back together and it worked temporarily. So now I am left with two broken mounting points and a huge hole in the inner liner. So short of cutting out a larger section of glovebox and making a new mounting bracket there is no solution other than ridiculous amounts of epoxy.
Personally I don't like temporary fixes, and the time necessary to design a new mounting point would not be worth it considering I would still have a piece that does not look as good as stock.
Old 06-28-2009, 07:09 PM   #10
ZachFD
ZachFD is on a distinguished road
do the 94-95 have the same design?
ZachFD is offline   Reply With Quote
Old 06-28-2009, 07:38 PM   #11
SLOASFK
SLOASFK's Avatar
SLOASFK is on a distinguished road
no, 94s and 95s had a different latch/handle design and placement.
SLOASFK is offline   Reply With Quote
Old 06-29-2009, 12:01 PM   #12
afgmoto1978
afgmoto1978's Avatar
afgmoto1978 is on a distinguished road
I have a friend who has three 93 gloveboxes in perfect shape. If anyone wants one PM me and I will forward you the contact info.
Adam
afgmoto1978 is offline   Reply With Quote
Old 08-29-2009, 06:54 PM   #13
NV02
Too little time
NV02's Avatar
NV02 is on a distinguished road
The internal screws fell out on mine as well. My approach to fix it was to drill holes from the back of the lid matching the internal screw holes. If you unscrew the latch and push it around internally, you can see where the screw hole are. I poured some Gorilla glue down the new holes, held the internals as best I could while screwing new screws from the back. It's held for a year so far.
Dave...
NV02 is offline   Reply With Quote
Old 08-30-2009, 10:07 PM   #14
kansei
Collector
kansei's Avatar
kansei is on a distinguished road
Mine never broke, nor did any screws work their way out, but ever since we got this car back in 1999, the glove box has never closed completely against the catch, and if you ever drive over any sizeable hole/bump, the door pops open (and spills the contents all over the floor). I recall checking all the recall work the car had done back when, and it showed something like 7 new glove boxes (!!). The car is an early one- December of '91 build date, so I always just chocked it up to that. Figured this one was probably a pre- or very early production car, before any running production line fixes/changes got implemented (it also had three ECUs and a couple of seat belt assemblies replaced). Since there isn't any adjustment in the latch or striker/catch, does/has anyone else had the same issue of the box popping open, and if so, how did you cure it? After ten years, it still drives me completely nuts. I never bought a new one since it had gotten so many already under warranty and obviously never fixed the problem.
Neal.
Neal "kansei" Swigert
Greenville, Michigan
www.kanseirotary.com
1973 Mazda RX-3 Wagon
1977 Cosmo
1974 REPU
1980 Mazda RX-7 GS "The Moozda"
1980 Brilliant Black Mazda RX-7 Leather Sport
1988 Mazda RX-7 10th Anniversary Edition
1993 Mazda RX-7 VR Touring Edition
kansei is offline   Reply With Quote
Old 08-31-2009, 01:01 PM   #15
bbade
bbade's Avatar
Mine would also pop open or not close, but that was just the latch on its last legs before fully breaking.
Sidenote, I didn't realize how hard it was to find a glovebox, still no luck!
