Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Defined Autoworks
Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Roll Cage Builds, Unique Fabrication and Transplants
Old 05-31-2009, 02:37 AM   #1
GtoRx7
*NEW* A/C and P/S 20b conversion kit for FD!
After months of work and planing, finally we can claim having the best of all worlds for 20b FD guys! Our newest kit is unlike anything else on the market. It still keeps the full stock subframe, and will not move the steering rack (which has made our current conversion kit such a success). But now keeps the Air Conditioning! In fact, it even keeps the a/c and p/s in the full factory locations! How did we do it? With more work, and more machining we actually moved the alternator over and down a few inches.Then completely changed the belt tension systems. The result? Perfect clearances with a FULL stock hood. Will work with Huge turbos! Will work with RHD cars! Will work with N/a! This is not replacing our previous 20b conversion, it is simply a optional upgrade for users wanting to retain a/c.
Features--
Keeps full stock subframe. NOT a subframe replacement
Keeps steering rack un-moved
Keeps full factory a/c system
Keeps Power steering system
Allows use of stock hood, no cutting or trimming needed, and still has over 3/4" clearance at the lowest point.
Uses stock size belt for a/c and p/s. And also uses a much easier to find, longer belt for the alternator/waterpump.
Other details--
This version still uses our same machined waterpump outlet, engine mounts, oil pan modification, and steering rack mods. So a previous customer can change to this model easily.
Here are a few shots of this new setup. I will have even more detailed ones soon.
Price $2070.00
DEFINED AUTOWORKS
Where concept meets results
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Old 06-30-2009, 12:59 PM   #2
War Eagle
War Eagle is on a distinguished road
Now you guys have the best solution available for the 20B conversion. For those of us in the south were AC is a must, thank you!
War Eagle is offline   Reply With Quote
Old 02-10-2010, 01:40 PM   #3
GtoRx7
Thank you
DEFINED AUTOWORKS
Old 02-12-2010, 03:45 PM   #4
20b 3rd gen
20b 3rd gen is on a distinguished road
Can UR underdrive pullies be used with this setup
20b 3rd gen is offline   Reply With Quote
