Old 05-23-2009, 10:02 PM   #1
FCTII
FCTII is on a distinguished road
issues need help
so my blow off valve was pretty much worn out it was a knock off hks and it caused a boost leak. i just recently replaced it and now it runs like a champ but the car wont idle. when i unplug the vac hose it idles just fine. if anyone could help me out that would be great.
FCTII is offline   Reply With Quote
Old 05-23-2009, 11:09 PM   #2
TehMonkay
idle air mixture might be set too rich, check the fsm, if not that try to adjust the idle speed.
Old 05-26-2009, 08:52 PM   #3
FCTII
i tried everything is there anyone around wausau WI that could help me out check it out i'll throw you some money???
Old 06-04-2009, 12:11 AM   #4
Mazdaracer4fun
S4 INTO S5 Turbo II OWNER
Mazdaracer4fun is on a distinguished road
take a video of your problems and what you do to keep it running. that will help a lil bit...also make sure the car is at normal operating temperature (fully warmed up) b4 taking video... my rx7 idles funny till its all warmed up ... after that its a dream! lol
Mazdaracer4fun is offline   Reply With Quote
Old 06-06-2009, 12:07 PM   #5
FCTII
in order to keep it running i need to hold my foot on the gas even when its warmed up. but it has a real jumpy idle whe the blow off valve it un plugged otherwise it wont idle when its plugged in. i'll take some video tho
Old 06-07-2009, 03:25 PM   #6
TehMonkay
Try and bump up the idle with the screw on the bac valve, i would turn it all the way in first then slowly back it out until it stays running.
Old 06-07-2009, 05:52 PM   #7
FCTII
there is no bac valve it was removed before i bought it.
