Old 05-22-2009, 06:51 PM   #1
Caim
Caim's Avatar
Caim is on a distinguished road
Weird Problem
So, ever since i have rebuilt the engine and ported it (street) i have been having a weird issue. It is intermittent so it does not happen all of the time. But it has been happening a little bit more then normal lately and starting to get on my nerves.
So here we go.... When i am driving and i let out of the throttle it will "bog down" or that is what i call it. It will stall as if it flooded itself out and i have to a) let it sit for a little bit and then try and start it (it will after a while of chilling) orrrrrrrrr b) start it (it will not stay started unless i pump the gas) and pump the gas pedal for a few minutes keeping it running until the problem clears up. It typically clears itself up after the car reaches 4k rpm for some weird reason. And then everything is back to normal. And off i go until it happens again.
So i am wondering if this might be a bad coil pack, a tune issue (but it happened on the base map as well), or something else that i can not think of at the moment haha.
The car is a 93 base, with a street port, gt37r single, full exhaust with no cats or res mid pipe, and well power fc.
Caim is offline   Reply With Quote
