Old 05-19-2009, 02:23 AM   #1
AndreS
AndreS is on a distinguished road
I need front sway bar measurements, please!
I'm looking for a sway bar for a different application, I'm considering using an RX8 front sway bar.
so.... I need some dimensions of a stock RX8 front bar, if someone would be gracious enough to help me out.
here's some dimensions that would be really helpful:
diameter
distance between mount points (inside to inside of bushings & outside to outside)
width @ end link mount points (inside & outside dimensions)
radius of rotation
AndreS is offline   Reply With Quote
Old 05-23-2009, 05:01 AM   #2
AndreS
bump, please help a guy out! can anybody with an RX8 take a tape measure and at least get some of them for me?
Old 05-24-2009, 08:22 PM   #3
sumdeus
sumdeus's Avatar
sumdeus is on a distinguished road
I could get you measurments of the rear tomorrow, its easy to access... but you want the front. The problem with the stock front sway is... it is hard to install, much less take measurments. I'll email someone who may be able to get the information for you.
sumdeus is offline   Reply With Quote
