Old 05-16-2009, 08:54 AM   #1
fire85gslse
fire85gslse's Avatar
FD fuel rails on the S5 motor?
Has anyone put fd rails on an s5 motor?
Would it work or would I have to run the FD upper and lower?
Old 05-16-2009, 10:20 AM   #2
Mobius
Rotorhead
The I know the secondary injectors are not in the same place, I've seen a S5 fuel rail mounted to an FD and it had to be lengthened considerably.
Old 05-16-2009, 10:51 AM   #3
fire85gslse
so if I run the fd intakes then that would not be a problem.
Old 05-16-2009, 06:39 PM   #4
Just get a KG Parts fuel system.
You can run an FD upper with a spacer/adapter from the S5 LIM to the FD UIM. You can't run the FD LIM. So it isn't as simple as just swapping intakes.
What are you trying to build Chad?
Old 05-16-2009, 07:29 PM   #5
fire85gslse
Want to get rid of the issues with leaking fuel (dont want my FC up in flames), and really like the new fuel adapters that Garfinkle made for my 3rd gen.
Maybe I should just go carb'ed....
Check you pm's DJ.
