Old 05-15-2009, 06:50 PM   #1
MotoTek
Always Under Construction
MotoTek's Avatar
How do I remove....there's a few things
I have everything on the front half of the car pulled off, and now am working on the rear.
So, at first I was going to remove just the control arms in the rear, and put in my new toe-link and trailing arms, but I'd like to pull out the subframe as well.
I see two long bolts that connect to the frame. Looks just like the same ones on the front subframe. Besides those 2, what else is there to disconnect? I see a control arm that looks as if it's mounted on top of the differential, is it connected to the chassis anywhere?
What about the CV Joints/Axels? Is this hard to remove from the brake control arms?
_____________
I removed all the bolts/screws from the alternator, and the cover's spin freely, but they don't want to see to come off. What else must I do? I was told heat the rear bearing with a soldering gun? I'm not sure I fully understand this.
Thanks for your help fellas.
BLACKADDE™ | ADGT RX7 |
