Old 05-08-2009, 07:34 PM   #1
89Rotary
GTUs 6 Port
89Rotary's Avatar
89Rotary is on a distinguished road
Dash Problems
Intrument Cluster won't work. Tach, Fuel Level, Amp, Temp, Check Engine, all those Guages won't work. Checked Fuses under dash and far as i can tell they are fine. Any Places i should start before tearing the Dash apart????
Also the Passenger Seat belt doesn't work no more, moved down when i open'd the door, but won't go back up.
also the Clock up in the Warning Clutser IS on, but nothing else. i do know that my Ignition switch is messed up. bein as i can take the keys out while driving, or start/stop with ANYTHING thats flat lol. you think maybe the Dash isn't reading the Switch is on, but the motor is??? i dunno tryin to get ideas..... Mazda wants 280.00 for one and they are the cheapest.
Jake B "Built NEVER Bought"
1989 Mazda FC3S GTUs
TII Swap In Progress
"Days Of Spoken Legend Has Come To An End, The Curtain Of The New Rotary Era Has Been Raised"
89Rotary is offline   Reply With Quote
Old 05-09-2009, 02:01 AM   #2
I am not sure if the ignition switch is directly causing this problem, but you know it is broken and needs to be fixed. I would start there,buying the part you know is broken, and installing it. If it still does not fix the instrument cluster, then at least you fixed something else that needed attention and can go from there. One thing you could try is to purchase a used "Steering column" with another switch+key on it, this will probably be cheaper than just getting the switch new. you can upgrade to tilt steering at the same time.
Old 05-09-2009, 02:41 AM   #3
Instrument cluster not working is usually due to some idiot mucking up the wiring under there - if you're running an alarm or aftermarket stereo, this is not a surprise.
Automatic seatbelts?
Take it to the Mazda dealer - there is a recall on them.
Warning cluster not working?
Common problem - cold solder joints needs to be redone.
Old 05-09-2009, 11:11 AM   #4
Check your "Meter" fuse. Even if it looks good it may not be good. Test it with a DMM (on Ohms). You could also replace the fuse and see what happens if you don't have a DMM (which I would hope you have one).
Old 05-09-2009, 07:38 PM   #5
89Rotary
GTUs 6 Port
89Rotary's Avatar
so i can take the Car to mazda and they'll fix my seatbelts? wow driver side has never worked lol....
i do have an aftermarket stereo, but i used one of the "plug into factory harness" and wire from there.
Old 05-09-2009, 07:41 PM   #6
89Rotary
GTUs 6 Port
89Rotary's Avatar
Is this fuse under the dash? or the Hood? cause under the dash, i have no cover so i don't know which fuse is which.....
Old 05-09-2009, 09:02 PM   #7
89Rotary
GTUs 6 Port
89Rotary's Avatar
Found the Problem......... a fuse, and i think its grounding out somewhere, but at least i know the problem.
Also i'm running a 15a fuse rather than a 10a fuse. problems??
Old 05-10-2009, 04:54 PM   #8
The Meter fuse is under the dash.
Here's diagrams if you don't have the cover. Taken from RX7club.com
First attachment is S4, second is S5.
Old 05-10-2009, 06:04 PM   #9
89Rotary
GTUs 6 Port
89Rotary's Avatar
the meter fuse is definatly the one thats gettin blown, and its now blown up to a 20a fuse, so its gotta be groundin out. tryin to figure out common places that wires ground out, or wear down.
