Old 05-05-2009, 11:10 AM   #1
FC3S Murray
frustrated!
FC3S Murray's Avatar
Brazing rear iron dowel on S4 13BT??
I have heard of earlier tuners doing it before the 13REW came out.
Anyone here done it OR seen it?
Same pig, new soul
Old 05-05-2009, 07:38 PM   #2
TehMonkay
No but i'm interested in hearing more
Old 05-05-2009, 07:52 PM   #3
what would this do?
Old 05-05-2009, 08:21 PM   #4
TehMonkay
prevent cracking the dowel landing.
Old 05-06-2009, 09:07 AM   #5
drewski86
Slow
drewski86 is on a distinguished road
I'm sure you'd have better luck picking up a S5 or REW rear iron.
drewski86 is offline   Reply With Quote
Old 05-06-2009, 11:07 AM   #6
FC3S Murray
frustrated!
just ordered a brand new S4 rear iron that comes from Mazda with the updated FAT casting.
Same pig, new soul
Old 05-06-2009, 11:09 AM   #7
TehMonkay
How do you know it does? I need more info.
Old 05-06-2009, 12:07 PM   #8
FC3S Murray
frustrated!
Mazdatrix told me so. They stated every new S4 rear iron comes with the updated casting seen on 13REW's.
They also recommended I replace my rear rotor housing becasue they state every rear iron break they have seen causes the rear rotor housing dowel hole to "oval". I asked for some measurement tolerences from them since the FSM doesn't specify.
I am awaiting a response.
Since I have a hair line crack and I pushed 17 psi once on low compression rotors when my WG went tits up(15.4 psi is my normal boost), I am skeptical that my rotor housing is "stretched". I guess I will see once I pull it apart.
Same pig, new soul
Old 05-06-2009, 01:07 PM   #9
classicauto
crash auto?fix auto
classicauto's Avatar
Yep at this point, all of the OEM stock is the later casting/thicker casting babies.
Interesting point about the ovalling of the dowel land in the housing, never thought about that but it seems to make sense - check it for sure though
Oh and have fun with the OEM iron's ports They're usually rougher then jason statham's stuble.
Old 05-06-2009, 02:37 PM   #10
FC3S Murray
frustrated!
Don't tell me that dude! I am already dreading attempting my first port job. I might practice on a scrap iron just to make sure I don't scar a 375.00 dollar part.
Same pig, new soul
Old 05-06-2009, 02:44 PM   #11
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Yes, it definitely takes practice. I tried it out on a junk iron before and made fatal mistakes multiple times. I do not recommend using a brand new iron for your first attempt at porting. You could probably pick up a junk iron or 2 for fairly cheap to learn on.
