Old 04-27-2009, 03:58 PM   #1
Turbo II
Zoom Freaking Zoom
Turbo II's Avatar
Brake Pedal Fade
On very hot days I've had my brake pedal fade pretty bad a couple of times. I had it happen once at VIR last year where they kept us in the staging area for quite a while on a 95 plus degree day where the pedal just started going to the floor while I was sitting there, but once I got on track it went away immediately and was fine the rest of the day. The other times have been very hot days driving in traffic which is what happened Saturday (92 outside). Any other time I can nail the pedal and it never fades. Just days where it's absurdly hot and I guess not getting the airflow through the engine bay.
I flushed the system last week using DOT 3 fluid and bleed it twice so it's not the old fluid and there is no air in it. Still have the original rubber lines but they look good, no cracking or anything. Like I said, they work fine 97% of the time. Any ideas?
1988 RX-7 Convertible
1991 RX-7 Turbo
2004 RX-8 GT
1985 RX-7 GSL - Sold
Old 04-27-2009, 04:32 PM   #2
Brent
Sua Sponte
Brent's Avatar
Have the brakes done it since you flushed them with new fluid? How often do you flush the fluid?
Old 04-27-2009, 04:44 PM   #3
Turbo II
Zoom Freaking Zoom
Turbo II's Avatar
Yeah I flushed it last Wednesday and it happened Saturday so the same problem with both the old and new fluid and like I said, only when it's really hot outside.
1991 RX-7 Turbo
2004 RX-8 GT
Old 04-28-2009, 09:54 AM   #4
Turbo II
Zoom Freaking Zoom
Turbo II's Avatar
Did some surfing and everything I find seems to point to if the pedal goes to the floor the MC is bad. I just found it odd it seemed heat related.
1991 RX-7 Turbo
2004 RX-8 GT
Old 04-28-2009, 10:40 AM   #5
Kentetsu
Kentetsu's Avatar
When the seals start to go in the MC you will find that light pressure on the pedal results in a slow drop in the pedal. But if you press really hard on the pedal it won't drop at all. The seals are going bad, and by pressing really hard you are "improving" the sealing. But when you press lightly, all the little imperfections in the seals allow the fluid to get by.
Good luck...
Old 04-28-2009, 10:56 PM   #6
Black91n/a
Black91n/a is on a distinguished road
You might want to consider building a heat shield for the master cylinder to shield it from radiant heat. That might just help.
Black91n/a is offline   Reply With Quote
Old 08-07-2009, 11:17 AM   #7
Turbo II
Zoom Freaking Zoom
Turbo II's Avatar
Just an update. It didn't matter if I pressed hard or soft the pedal would slowly go to the floor on +90 degree days. I replaced the MC not long after I posted this thread and it fixed the problem.
1991 RX-7 Turbo
2004 RX-8 GT
Old 08-08-2009, 12:18 AM   #8
killahrx7
killahrx7 is on a distinguished road
change to DOT 4 it's a temperature issue. it has a higher boiling point
88 turbo II(streetsweepah) 13b rew full bridge wolf3d v500 tuned by 3FACE RACING. bigup Waynespeed and Juankel Performance
killahrx7 is offline   Reply With Quote
Old 08-08-2009, 12:59 AM   #9
Geez people, the OP said it was the master cylinder that was bad.
That would've been my first suggestion since it didn't sound like the brakes were being that abused.
It takes a LOT of abuse to get the brakes to fade - the stock brakes are already pretty good for stock.
Even extemely hot ambient temps should not be enough to make them fade on you.
I've driven my FC in 105+ F Sacramento summers and 110+ F Vegas summers with no hiccups from the brakes.
