Old 04-22-2009, 08:23 PM   #1
morondongon
morondongon's Avatar
morondongon is on a distinguished road
Moroso Oil Pan
Has anyone here used an Moroso Oil Pan on their 13B? I'm contemplating about it... if so which one? here are the links
http://www.moroso.com/catalog/catego...?catcode=12119 & http://www.moroso.com/catalog/catego...?CatCode=11116
Love driving my 7
morondongon is offline   Reply With Quote
Old 04-22-2009, 10:49 PM   #2
Neither of those pans will work on a 13B from an S4 or S5. The only possibility would be to move the engine further back and down, which is possible, but you need to do a lot of work to do that.
Old 04-22-2009, 11:23 PM   #3
morondongon
I kind of figured... I was looking into see if anyone has actually tried or used one. There are some people that say you actually gain some performance by reducing the engine flex...
Love driving my 7
Old 04-22-2009, 11:29 PM   #4
There's other ways to accomplish that.
Honestly though, why not just go dry sump and be done with it?
Old 04-22-2009, 11:37 PM   #5
Yep, those pans are only made for pre-86 13B's, and will not fit FC or FD 13B's with stock engine mounts.
You're going to redo your stock engine mounts just to get this thing to fit???
I doubt having a beefier oil pan flange will actually make the engine stronger...
Under 300hp 13B's should not need it.
Over 400hp 13B's should seriously look into dowelling.
Another option is to go with the Banzai oil pan engine brace?
I would never use it on my cars though...
Old 04-23-2009, 12:57 AM   #6
morondongon
Ok where can I get more info on dry sump and dowelling? I was researching a bit more and came across the pineapple racing pan for the FC. I'm thinking this might be what would work best... Let's not forget that this is a street car...
http://www.pineappleracing.com/index...ROD&ProdID=106
Love driving my 7
Old 04-23-2009, 01:43 AM   #7
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Appearently the pineapple ones crack real easy, i have heard horror stories of people knicking stuff in the street and losing all there oil and killing there engine before they knew anything was wrong. But i was also told that they stick past your frame, which pineapple states they do not, so whether or not theres any truth behind the stories is not worth testing to me, i was considering one at one point, but if your car is stock and you dont auto-x or anything theres really not much point.
Old 04-23-2009, 09:05 AM   #8
Fidelity101
Reliable Source
Fidelity101's Avatar
You loose power to your wheels with the back and forth motion of the motor as it rotates, they don't increase your HP it just helps you deliver more of it to the ground.
thats why people have solid motor/trans mounts... like me!
if you want to beef up your oil pan get an oil baffle plate, I highly recommend one. No more low oil level buzzer on high G cornering for me!
My Rx-7 Vids
Old 04-23-2009, 09:49 AM   #9
morondongon
I don't auto-x but would like to ge the most of my engine... I want to get I ready so when I go to the dragon next year I will not be left behind.. After some turns...
Love driving my 7
Old 04-23-2009, 02:27 PM   #10
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
The stock oil pan does its job pretty well for the street, that 400 bucks that you could put towards engine cooling for that 11 miles of hard running
Old 05-04-2009, 08:58 PM   #11
RotorDad
Big Ugly
RotorDad's Avatar
if you are looking to beef up the motor to reduce the motor from flexing you can get extra dowels "doweling" as said above or there are a few companies that make enlarged dowels. my motor has extra dowels, solid motor mounts & a torque brace bar to eliminate engine shutter / movement. i have never seen anyone try to fit the moroso oil pan in a FC application.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 05-05-2009, 11:39 AM   #12
classicauto
crash auto?fix auto
classicauto's Avatar
Crack easy: well it is cast aluminum......but if you ran over something thats going to break the FC pan where it sits - you're going to tear through your radiator/oil cooler and subframe first.................so really - its a non issue.
Stick under the car: No. Not the FC pan.
I love mine. I just wish they'd make some REAL FUCKING DRAIN PLUGS for it instead of the retarded allen key pieces of shit they sell with it. I had to tack some nuts on them after the teency weency little allen key piece stripped (2-3 oilchanges)
Its not a really "necessary" mod though. Yes, my car holds quite a bit of oil now. Yes, the pan hasa windage tray and a very well designed baffle system - but those can be added to a stock pan with $5 worth of sheet metal. Its mostly a bling piece.....
Old 05-17-2009, 05:11 PM   #13
Fidelity101
Reliable Source
just give your stock pan an oil baffle plate.
My Rx-7 Vids
Old 05-17-2009, 07:15 PM   #14
Baffling would be nice, I lost quite a bit of oil from the filler-tube from my auto-x today. So when I pull the motor I'll definately be adding that along with something in the oil fill tube to prevent the oil from getting everywhere..... again.
The extra 1.25 qts would be nice but there are other ways to get it.
If your biggest concern is getting through the dragon, I would think that there are other ways to get through it than with a different pan. What's the problem with the way it is now?
Oh, I also heard that the Pineapple pan likes to let oil seep through it. The o-ring seal is a nice little touch though.
Old 05-17-2009, 08:35 PM   #15
Fidelity101
Reliable Source
rotaries are like jeeps, they leak and they run lol
My Rx-7 Vids
