Old 04-20-2009, 05:38 PM   #1
Nopis1O
Nopis1O's Avatar
Nopis1O is on a distinguished road
spark problem
IM NOT GETTING SPARK! trying to figure out why.
when i do the test procedure it sparks. but when i hook it back up and try to crank it its not. i know it worked when i pulled it apart. so i messed up something.
if anybody has any suggestions for me to try letme know. i will try just about anything at this point. its probably a simple fix that im just over looking.
1988 Fc Vert. Super Stock
1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
Nopis1O is offline   Reply With Quote
Old 04-20-2009, 11:51 PM   #2
Rotary#10
Rotorhead
Rotary#10's Avatar
okie what procedure did u do to test the spark ?
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 04-21-2009, 01:26 AM   #3
i would like to know exactly what you did as well. Are you simpling using one of those illuminated spark plug testers?
Also, are you not getting spark for leading AND trailing?
Old 04-22-2009, 09:06 PM   #4
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
How do you know its not sparking? Besides it wont start. That could be plenty of other stuff stopping that, so did you take it apart, test for spark, have spark then put it back together, it not start then check it again and you didnt? Or just assume you dont because it wont start once its back together?
Old 04-22-2009, 09:36 PM   #5
A timing light will not show spark, even if it is working.
If both leading plugs are not in place, neither will spark.
If your tach works, you have spark. (unless the trailing coil is bad)
