Old 04-20-2009, 10:56 AM   #1
sumdeus
sumdeus's Avatar
sumdeus is on a distinguished road
Misfiring
Ok, so while running a night run at DGRR this last weekend, I threw a CEL at high RPM/full throttle. So I got home and got an OBDII scanner; the CEL is a P0302, rear rotor misfire. The scanner recorded the last occurrence at about 2200-2300RPM and around 27mph.
The CEL light will not flash as long as the revs are kept below about 6k. So what should be my next step to fix this misfiring? Its a 2007 with about 32k miles. Any help would be appreciated. If you need any more details let me know.
Edit: When the CEL does light up, the car falls flat. Power just dies (similar to hitting a fuel cut off or rev limiter).
sumdeus is offline   Reply With Quote
Old 04-20-2009, 12:46 PM   #2
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
New Ignition Coils, Wires and Plugs time.
It is a known weakness with the RX8 - coils don't last so long.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 04-20-2009, 12:51 PM   #3
SPICcnmFD
SPICcnmFD's Avatar
Yep it doesn't take much to foul plugs in a rotary. Start with the cheapest possible fix and work your way up. I'd say with only 32k the wires are probably ok, but it wouldn't hurt to change them. Aren't bad coils a common problem on the 8s, at least the earlier ones??
1993 Rx-7 SM2 #11
At the local AutoX:
Speed for Sale shootout 2007:
A few laps at Barbers:
Old 04-20-2009, 08:05 PM   #4
sumdeus
sumdeus's Avatar
If it is indeed the coils, anyone have any experience with the BHR ignition setup?
Old 04-20-2009, 11:05 PM   #5
Kane
All about the O2
Kane's Avatar
I do - it is great...The big upside is they will last a long damn time - and new coils are $20....
Old 04-21-2009, 08:39 PM   #6
05rex8
Turbo 8
05rex8's Avatar
05rex8 is on a distinguished road
at first I had lots of misfires with my turbo setup and the bhr kit...however there seems to be a fix for it and I will be trying it again
for N/A it worked fine as is
for turbo setups, apparently the dwell needs to be changed
05rex8 is offline   Reply With Quote
Old 04-23-2009, 01:06 PM   #7
Kane
All about the O2
Kane's Avatar
Yep - dwell above 330-340 g/sec is not enought to light the higher density charge - but for NA they are fine.
Old 04-29-2009, 06:05 AM   #8
Flashwing
Flashwing is on a distinguished road
sumdeus sorry to hear you've discovered the fact that the stock ignition system isn't up to snuff.
There's some great advice here in terms of going with the cheapest or cheaper replacement stuff first and then working your way up. Plugs are something that should be changed about every 25,000 miles to keep your rotary performing well.
The stock ignition coils are the weakest link of the whole system. While you can typically get a replacement of all 4 coils for around $140 with shipping retail, BHR does offer an alternative using the yukon LS2 coil which is higher quality and produces more spark.
If you're running an N/A setup, the kit is a plug and play solution. We've found there's some tweaking necessary should you go turbo or supercharged but those changes are not required with N/A setups.
I'd be happy to answer any questions you may have regarding the ignition system.
Black Halo Racing - We don't sell parts, we solve problems!
Flashwing is offline   Reply With Quote
Old 05-18-2009, 04:49 PM   #9
bose
Member
bose is on a distinguished road
I love my BHR coil kit. Fantastic especially in the upper RPM range's. But at any rate your ignition coil have had it. That much I'm sure of and change the spark plugs just for good measure. It's possible you could get away with just cleaning them, but I would do it just for posterity's sake.
bose is offline   Reply With Quote
