Old 04-10-2009, 12:20 AM   #1
IH8DSM
IH8DSM's Avatar
fusible link
Alright so i fryed my fusible link on the gsl se, its the one that runs to the alternator and to the ignition. We replaced it with a fuse and now everytime we start it it will pop that fuse. The wire going to the alternator appears to be good no burn spots or anything. my question is how hard is it to get the wire going to the ignition out and could it possibly be something else
Old 04-10-2009, 01:26 AM   #2
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Check the alternator.
Old 04-10-2009, 02:00 AM   #3
IH8DSM
IH8DSM's Avatar
it blows em when its not hooked up to the alternator so it can't be that right. Like itll start run for a second then pops the fuse so its gotta be something past the ignition that it grounds to right?
Old 04-10-2009, 06:53 AM   #4
The wire never was on the alternator when it blew right? The battery was connected, they wire was removed and touched a ground?
So the alternator should have NOTHING to do with it.
Old 04-10-2009, 11:10 AM   #5
use a multimeter to check before and after the fusible link... neither should have 0 resistance when the other probe is grounded
Old 04-10-2009, 12:34 PM   #6
-xlr8planet-
-xlr8planet-'s Avatar
what kind of fuse do you use to replace a fusible link?
Old 04-10-2009, 01:15 PM   #7
IH8DSM
IH8DSM's Avatar
we tryed 10,20s, 40s it would pop em all
well if these storms ever lighten up i will get charles too take a look
i removed the wire off the alternator, and then it hit the alternator and popped the fusible link
but the car started last night and sounded awesome just need to get this wiring thing figured out and ill be good to go
Old 04-10-2009, 02:16 PM   #8
congrats on getting it started, i'll be over there after work to see your handywork.
Old 04-10-2009, 04:01 PM   #9
IH8DSM
IH8DSM's Avatar
i may be there may not gonna give this storm a little more time for the traffic to dye down
Old 04-10-2009, 10:54 PM   #10
FirstRotaryExp
wait...let me get this straight. You tried using a 10 amp, 20 amp, and a 40 amp fuse to hold current against a MINIMUM 70 amp alternator?
When I replaced the ungodly fusible link block in my buddy's gsl-se I used a FC fuse block and bracket. used the FC fuse pattern and matched everything up nice and tidy. NEVER once blew a main fuse (which is the alt fuse), and we bolted up a S4 fc alternator and used the stock 80amp fuse to keep the power in check.
Slightly shitty pic of it installed, and sadly the only picture of the setup, but it mounts to one stock bolt hole, then you may have to drill and rivet the other hole, or look into a re-speed mounting bracket.
Old 04-10-2009, 11:52 PM   #11
IH8DSM
IH8DSM's Avatar
we were trying to look up the amperage on the fusible link and couldn't find anything on it. we think its the alternator thats poppin the fuses im gonna change it tommorow and see if that fixes it thanks for the info may switch it to the fc block
Old 04-10-2009, 11:55 PM   #12
FirstRotaryExp
Np, I didnt see anyone post anything regarding the main fuse/ fusible link amperage so I figured it could help seeing as you tried everything that was far too small. Ive got a spare FC block that im going to use on my StarQuest soon as I get some straight amperage answers from those guys...
Old 04-11-2009, 01:00 AM   #13
IH8DSM
IH8DSM's Avatar
im sure charles has a spare harness hes got a spare everything else haha, if not ill just have to wait till after the gap to swap it out.
Old 04-11-2009, 11:29 PM   #14
IH8DSM
IH8DSM's Avatar
IT RUNS woot
Old 04-12-2009, 12:59 AM   #15
FirstRotaryExp
So what fixed it to stay runningish?
