Old 04-02-2009, 06:38 PM   #1
NOLA RX-7
NOLA RX-7 is on a distinguished road
Question ECU question??????
Is a tll ECU diferen than tll JDM????
NOLA RX-7 is offline   Reply With Quote
Old 04-02-2009, 08:46 PM   #2
yes.
will it work? maybe . Someone else will have to explain the differences.
Old 04-03-2009, 07:27 AM   #3
NOLA RX-7
Yes is diferent?
Old 04-03-2009, 11:38 AM   #4
yes there are differences.
Old 04-03-2009, 03:15 PM   #5
they are pretty much interchangeable. Its the the N318 vs. N319 or N370 vs N374 in question?
Old 04-03-2009, 05:23 PM   #6
NOLA RX-7
Angry
well :wallbash:i have a JDM engine But the ECU is not. So i think thats my problem.
Old 04-04-2009, 01:45 AM   #7
what do you mean? Is there a specific issue your running into? It *should* be cross compatible. The engines are the same essentially only some not major differences.
Old 04-04-2009, 10:08 AM   #8
NOLA RX-7
Unhappy
well my car runs fine for cople minutes then starts to misfire. Tps is ok. gas pump is new,filter to. So the only thinc tocome to my mine is ecu. or i am rong.
Old 04-04-2009, 11:57 AM   #9
could be a bad sensor or perhaps just the ecu you have is bad. Sounds like once it starts to warm up (where the ecu would start to alter fuel mapping) it gets pissy.
Old 04-04-2009, 06:01 PM   #10
NOLA RX-7
so change the ecu...
