Old 03-31-2009, 08:53 AM   #1
NOLA RX-7
NOLA RX-7 is on a distinguished road
Need your knowledge.
I have no idea where or what to do . I have no boost reading .please help tk Where i should connect these lines.
Another thing when i press the gas to go fast the car starts to miss fire please any one with the knowledge help...
NOLA RX-7 is offline   Reply With Quote
Old 03-31-2009, 12:00 PM   #2
Boost leak somewhere most likely.
The first pic is nothing, I have the same uncapped pipe there.
The second pic, I don't know what you are trying to show, but it looks like you need to have that vacuum hose going to the boost sensor (stock ECU??) teed off to the wastegate/boost gauge.
The third pic looks like the same style plug as an injector, but I don't know why it is down there. I can see behind it though that the ground tab is not connected. That isn't good at all.
Old 03-31-2009, 12:38 PM   #3
NOLA RX-7
cant u send me pic of your car , of the same parts.tk
Old 03-31-2009, 01:22 PM   #4
I will put some up after work. So after 5pm CST.
As long as your is S5 with no emissions, it should be similar.
Old 03-31-2009, 03:22 PM   #5
NOLA RX-7
Talking
yeap is S5 TK
Old 03-31-2009, 03:54 PM   #6
In the third pic, I think that might be the plug that connects to the oil level sensor on the oil pan, or maybe it connects to the transmission wiring?
Old 03-31-2009, 04:56 PM   #7
do you have a hose clamped to a hose?? .... boost leak
Old 03-31-2009, 06:41 PM   #8
OK, same order as your original pics-
#1- Rats nest lines to nowhere.
#2- Diagram of how I have my boost goodies set up.
#3- That is for the oil level sensor. Could not get a good pic since mine is covered in crud, and the flash didn't help, but here it is.
Old 03-31-2009, 06:46 PM   #9
AWWW, someone learned basic photoshop....
and is that rust on the tip of your blow valve?
lol
Old 03-31-2009, 06:53 PM   #10
Yes. That fucking car cover kept all the moisture UNDER it!!
Piece of crap.
Old 03-31-2009, 07:05 PM   #11
NOLA RX-7
Piece of crap.
TK but what about the 3 vacuum hoses from the ACV. there going to the gray yellow and blue connectors by the oil fill.
Old 03-31-2009, 07:07 PM   #12
his motor has no emissions... you need to find you an emissions diagram and your search will end
Old 03-31-2009, 07:09 PM   #13
NOLA RX-7
so i block those 3 lines.
Old 03-31-2009, 07:13 PM   #14
If you are going emission delete........you basically block EVERYTHING except for a select few.
-Leave the large port on the backside of the TB for the Oil Injector Vacuum spider (unless you are pre-mixing, then cap it)
-Leave the large port for the brake booster
-Leave the port on the turbo side of the UIM (pictured above) for boost reference
-Leave the port for the Fuel Pressure regulator.
Everything else is capped off.
That is really all you should have if you are emission free.
Old 03-31-2009, 07:18 PM   #15
NOLA RX-7
you are talking in the back of manifol between the butterflies and manifol.right can i call you or you call me 239-281-9768 michael
