Old 03-07-2008, 10:48 AM   #1
6p turbo LOW OIL PRESSURE!
This is updated from the other forum where originally posted...
motor:
- s5 6port turbo conversion
- s5 n/a block, stock s5 t2 everything else
- oil feed line taken from aftermarket oil pedestal
- tapped n/a cover for stock turbo oil return
- autometer sport comp elec. gauge in stock location
- mech oil pressure gauge in pedestal
problem:
Oil pressure upon initial startup of the motor was around 28-30 psi at idle and above 50psi at rpm. as motor warms up, oil pressure declines.
startup cold:
25 psi at 800rpm, 50 psi when I rev.
hot driving:
30-35 psi at 2k, 40-50psi from 3k on.
hot idling:
0-10 psi at 800, 15-20 psi at 1200.
Other:
- oil psi does not decrease (just stops around 50psi) at higher RPM
- 20w50 Castrol conventional
- Pure-one oil filter
- gauge wiring has clean, tight connection
mech gauge tested... pressure on the electric gauge accurate,
mech gauge shows 10psi at idle
oil is a grayish color, similar looking to antisieze (for threads) but darker and without being shiny... Is that a telltale sign of anything??
Old 03-07-2008, 12:55 PM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
Mileage on the engine? Could be a failing regulator.
EDIT: also, just realized this was a 6Port turbo...
The way you've done turbo oiling *seems* alright, shouldn't affect the pressure too much....
Greyish oil is a sign of contamination (obviously) that may have come from bearings.
Old 03-07-2008, 12:59 PM   #3
I can answer a few questions for Paul, since I helped build it.
Mileage really is unknown. We bought the engine from a 7 lover in Bama. We pulled it out of the car, running perfect. The engine ran great and had no issues.
We did the 6 port turbo conversion, using all TII factory parts, with the exception of the Japan2LA modified LIM. After the conversion is when the motor's oil pressure started acting funny.
I recommended replacing the regulator, but we haven't yet.
Old 03-07-2008, 01:07 PM   #4
Its the pink fender
Old 03-07-2008, 01:08 PM   #5
Its the pink fender
SSSSSsssshhhhhh..............
Old 03-07-2008, 03:15 PM   #6
classicauto
crash auto?fix auto
Hmm, well I'd say the regulator would be a good place to start. There's not many things that would lower the pressure significantly other then the pump (its possible, but I've never seen a bad one) the regulator really.
Tough call.
But with greyish oil, I'd be addressing this sooner rather then later.....ideally immedeatly rather then sooner
Old 03-07-2008, 10:10 PM   #7
i'm working on an escort that I just got running to be my DD while i tear it down, so it'll be just a few more weeks until I can try to change it....
I've read that greyish oil is a sign of water or coolant, but I'm not losing any... could the turbo itself be failing internally causing probs?
Old 03-07-2008, 10:14 PM   #8
Need any help, let me know
Old 03-07-2008, 10:20 PM   #9
the pink fender was there when the engine was fine... look at the deal's gap pics sshheesshh
Old 03-07-2008, 10:29 PM   #10
I know, I just figured I would say it before DJ did
Old 03-08-2008, 09:02 AM   #11
J-Rat
J-Rat is on a distinguished road
What about the oil ring behind the front cover? Thats notorious for dropping out and causing low oil pressure issues.
Rat
1988 10th Anniversary
554 RWHP, 395 RW Torque
10.7 @ 126!
owner:
www.azrx7.com
Engine built by ARIZONA ROTARY ROCKETS
www.azrotaryrockets.com
J-Rat is offline   Reply With Quote
Old 03-08-2008, 10:40 AM   #12
^ That's what RETed mentioned on 7club, that is very likely.
Old 03-08-2008, 10:47 AM   #13
Yup, I think we just need to pull the front cover off and go from there. I know he doesn't want to do it, but hey its worth a shot and DGRR is coming up quick. Hopefully he can tear it apart next weekend when he can use my garage.
Old 03-08-2008, 10:55 AM   #14
I really hope he can get this resolved by DGRR, we don't want another Rest Stop incident
Old 03-08-2008, 10:56 AM   #15
classicauto
crash auto?fix auto
Well in my experience by the time you get enough water in your oil to actually change it a greyish colour, you'd need to be missing alot of water.
If anything its a combinaiton of poor crankcase venting (and the moisture that would put in the oil) and other contaminants that are changing the colour.
