Old 03-18-2009, 11:45 PM   #1
EGR Wire
I'm sitting here looking at my engine harness trying to remember which color plug attached to which solinoid that directed air to actuate the EGR. I don't have the rats nest near by, but I'll be checking the FSM soon. I just for the life of me can't remember which wire it is.
I plan on removing the clips for the different solenoids and use the EGR as the output for the boost control solenoid to handle my 6PI delivery. I'll also need to alter my Var-Resistor to be my Alternate input for logging my AFR's. But which wire to I prep for input... I guess I'll check out to see what RTek says about which wires.
Old 03-18-2009, 11:52 PM   #2
Confirm: Blue and White is output voltage for EGR?
Old 03-19-2009, 11:44 PM   #3
3rd and final 7
3rd and final 7's Avatar
3rd and final 7 is on a distinguished road
i beileive it yellow, check this diagram out.
edit this is for a s4 im not sure if you got a 4 or 5
3rd and final 7 is offline   Reply With Quote
Old 03-19-2009, 11:49 PM   #4
The solenoid is yellow. The wire I need however is blue/white. which is on the yellow plug. Thanks for your help!
