Old 03-15-2009, 10:07 PM   #1
lcrotaryracer
lcrotaryracer is on a distinguished road
has some one done this
swaped a miata engine in to a fc. 1.6 or 1.8. if some has tell me about it.
you can always have fun in a rx7
lcrotaryracer is offline   Reply With Quote
Old 03-15-2009, 11:55 PM   #2
seriously? have you ever driven one??? You thought your NA was slow!
just step out of the piston swap section and nobody will be hurt....I'm leaving since I can feel the hives coming.
Old 03-16-2009, 11:45 AM   #3
Why would you want to swap in a motor with less initial HP than the stock engine?
I have a Miata, and reluctantly swapped the 1.6 for a 1.8. I wish I could have gone with a rotary swap, but $$$ prevented it.
Old 03-16-2009, 12:22 PM   #4
lcrotaryracer
my na was so slow in the 8th mile it ran a 11.09. that is very slow. my buddies miata ran a 9.5 and drove it in ran a 9.1. but maybe a fresh engine would do better. im really leaning to a 13bt swap.
Old 03-16-2009, 12:27 PM   #5
but a miata weighs about 500lbs less than an FC... rebuild will be way cheaper and less headache
Old 03-16-2009, 12:46 PM   #6
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
i thought about it once... mostly because i had an FC shell sitting there and a 1.6 miata drivetrain sitting there... but never really went beyond considering it.
Old 03-16-2009, 01:47 PM   #7
Just sell the shell/ part it out or go TII and never look back.
Old 03-20-2009, 12:46 PM   #8
Proxy One
Victory Is Mine
Proxy One's Avatar
Proxy One is on a distinguished road
Ive actually heard of a guy who put a miata engine in a FD. I think it was in Alabama but not sure. Maybe someone else here will chime in that knows what im talking about. They supposedly did it just for reliability.
www.dealsgaprotaryrally.com
1994 Rx7 White 2001 RZ GT35R'd
1972 Rx2 Orange Coupe 5spd
2006 STi
1986 Buick GN
Proxy One is offline   Reply With Quote
Old 03-20-2009, 02:32 PM   #9
That's like going to a B-cup from a C-cup for posture.
Old 04-05-2009, 02:09 PM   #10
SouthSideSlider
SouthSideSlider's Avatar
SouthSideSlider is on a distinguished road
actually a BPT would be nice it has similair stats to the T2 motor 210Hp its a turbo 1.8L miata motor basicly
2000 Acura Integra GS: daily driver
1990 Mazda RX-7 GTU: parts car.
1986 Mazda RX-7 base: under the knife.(no sunroof!!!)
1989 Volvo 745 turbo: B230ET,19T turbo,850 Turbo injectors,HKS Manual Boost Controler,Port/Polish,Oversized valves,titanium valve springs,M-Cam,G80 locker,modded AW71 transmission.
SouthSideSlider is offline   Reply With Quote
Old 04-08-2009, 11:02 PM   #11
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
seems really pointless just get a miata and do it the other way around
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 04-08-2009, 11:56 PM   #12
Still, the MS miatas are bad themselves....no point in taking the motors out of them.
I don't understand the point of swapping for equal or less power. All that work for the same or worse power to weight.
And isn't the MS 180hp?
Old 04-17-2009, 05:38 PM   #13
rotaryextreme
i like spinners
rotaryextreme's Avatar
rotaryextreme is on a distinguished road
Seriously, if your considering to go with a 4 cylinder.
20 valve 4age N/A, or an (stock 210-215) sr20ve-yes VE, there is a mechanical vtec version of the sr20de motor. Those are 2 good very affordable N/A motors.
You want reliableish turbo power, sr20det.
Those will be worth the hassle and your time.
And once the renesis get cheaper, that will be a slamin swap for an all motor FC, and it can be legalized because it is a newer motor of the same type. State ref will pass you.
My 2 cents.
The ingenious and decidedly weird Wankel rotary engine works by using internal combustion to bounce a fat metal triangle around inside a hollow metal kidney bean, which hula-hoops around a central shaft to generate power.--- Jalopnik www.rotaryextreme.com, after more then a 2 year break, Rotary Extreme Re-opens 9/11/08.
rotaryextreme is offline   Reply With Quote
Old 04-25-2009, 01:21 AM   #14
JShiz
ZOMG WTF BBQ!!!
JShiz's Avatar
I know a guy that put a 1.8 in a FC. He's going turbo... I'll told him i'll race him with my FB for kicks once he's done with it.
Old 05-01-2009, 07:52 PM   #15
RotorDad
Big Ugly
RotorDad's Avatar
a good friend i have was a SR20 freak, when he sold his 240 he found an FD with a blown motor & decided he was going to do a SR20DET swap. he worked at a local performance shop & went on with swap using leftover upgrades. i hated the car & still do
Boosted Big Body On 335's
PS3 ID: Rotordad
