Old 03-15-2009, 06:08 PM   #1
AHarada
Good front speakers?
I'd like to upgrade my front speakers. There are some cheap Jensen speakers in the front right now, and they are installed with an adapter plate kind of thing. With that adapter plate though, the speakers hit the door panel when installed and won't fit without the plate. Are there any decent speakers that will bolt up to the stock plastic speaker holder things? Preferably airtight against it.
Old 03-15-2009, 06:11 PM   #2
AHarada
Forgot to add that I have the standard audio system, and NOT the Bose.
Old 03-15-2009, 06:37 PM   #3
proz07
Needing a new tow rig.
proz07's Avatar
picture of this interfrence as im waiting on adapter to install my JL's?
z
Old 03-15-2009, 07:47 PM   #4
AHarada
Here's the door panel with the speaker grill off. The door panel isn't sitting flush on the door here. I can install the door panel still, but I need to force it just a little bit to flex it.
Old 03-15-2009, 09:32 PM   #5
proz07
proz07's Avatar
hmmm what des the actual adapter look like? i ordered some premade MDF ones that fit a 6.5" they should be in this week ill take a pic so you can compare yours i dont know if they will it yet but im assuming so. as my roomate did the same in his lexus and they fit just fine.
hell you can even look them up on ebay if you want to see what they look like... actually here
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
ill report back on fitment when i install them. sorry that dosent help you problem right now though
z
Old 03-16-2009, 12:33 AM   #6
AHarada
Hey those are cool, I've never seen those. Those actually replace the entire plastic housing for the front speakers. The ones I have are just a simple plate with different mounting holes that screws to the plastic housing, then you screw the speaker on. That one definitely looks like a better solution. I wonder if those sit flush against the door, which I doubt they are. The surface where it screws too isn't flat, so the MDF would have to be cut perfectly to fit. I think you may have an issue with the speaker magnet hitting the window also, so possibly speaker options might be slimmer.
Old 03-16-2009, 08:26 AM   #7
DARKMAN
DARKMAN's Avatar
DARKMAN is on a distinguished road
try infinity
You can try Infinity 6022si I can sell them to you for 79.95 before shipping the moumt depth is just 1 15/16" or 48mm. and they sound great
DARKMAN GO BUMPTY BUMP THREW THE NITE
DARKMAN is offline   Reply With Quote
Old 03-16-2009, 11:16 AM   #8
Proxy One
Victory Is Mine
Proxy One's Avatar
Proxy One is on a distinguished road
I have some Infinity Kappa 6.5"'s in mine and they sound awesome.
www.dealsgaprotaryrally.com
1994 Rx7 White 2001 RZ GT35R'd
1972 Rx2 Orange Coupe 5spd
2006 STi
1986 Buick GN
Proxy One is offline   Reply With Quote
Old 03-16-2009, 03:51 PM   #9
AHarada
How did you guys install them? Did you use some kind of adapter plate? It looks like the Infinity's only have 4 mounting holes, and the FD has 3, so I don't see how that would work.
Old 03-18-2009, 06:58 AM   #10
allrotor93
allrotor93 is on a distinguished road
the MB QUart 4" speakers fit in the bose pod perfectly....what size is the hole?
allrotor93 is offline   Reply With Quote
