Old 03-12-2009, 11:28 PM   #1
lcrotaryracer
lcrotaryracer is on a distinguished road
need some help i thank its gone
i have a s4 nt gxl, no emissions on the car. put a new clulch on the car. now it it seems like it has a big cam like a piston engine. flooding alot when cold.
im going to look it over tomorrow. and also i took out 5 & 6 port sleaves.
its not right not like it was before i took the engine out. i will have more info tomorrow.
please give me some ideals on what may or is wrong. thanks
you can always have fun in a rx7
lcrotaryracer is offline   Reply With Quote
Old 03-12-2009, 11:42 PM   #2
well if you want to do the poor mans compression check, remove both leading plugs and the EGI and INJ fuses. Have someone crank the car while you listen in the engine bay. Should have 6 even "whooshes" as the compression goes past. If you have a pulse or two that sound weak then there is a serious issue.
Old 03-13-2009, 01:15 AM   #3
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Then I'm willing to bet something went wrong during re-installation. Did you miss any plugs? Are the injectors all plugged in right? Did any wires get damaged in the process?
when the wires to 2 of my injectors cracked, my FC ran on one rotor. Something you might want to check out.
Old 03-13-2009, 07:00 PM   #4
lcrotaryracer
well good bye to this one. coolant seal in rear housing. but good thing the car still look good
Old 03-14-2009, 01:31 AM   #5
Join the club Time for a rebuild and port!
Old 03-15-2009, 02:11 PM   #6
well, coolant seal is not too bad. My engine had the front iron's seal go out.
PS: I have a rear iron available for cheap, but it might need to get lapped.
Old 03-15-2009, 10:14 PM   #7
lcrotaryracer
i am going to a turbo engine or piston. right now gettn some money to do it.
