Old 03-08-2009, 05:40 PM   #1
ThunderCougarFalconGoat
ThunderCougarFalconGoat is on a distinguished road
Mikuni Side-draft Tuning
Hello guys, new poster here. I was wondering if anybody had any experience playing with Mikuni side-draft carbs?
Its on an gold '82 junkyard special with a 12a that I picked up last july. I'm a carb virgin, and nobody I know wants to touch a side-draft, so any help would be appreciated.
Thanks in advance.
ThunderCougarFalconGoat is offline   Reply With Quote
Old 03-08-2009, 07:16 PM   #2
TheDriver216
TheDriver216's Avatar
What info you need? I have a Weber sidedraft.. whats going on with it?
Old 03-08-2009, 07:33 PM   #3
Well is seems to be low on power, even for a rotory. I'm really just looking for general tuning tips and procedures, as I've never messed with carbs at all before.
Old 03-08-2009, 08:02 PM   #4
TheDriver216
What size is the carb? Choke size? jet and venturi sizes? air bleeds?
Old 03-08-2009, 09:34 PM   #5
I have no idea how to tell these things. It was already installed on the car when I got it.
Old 03-08-2009, 10:55 PM   #6
TheDriver216
did you do all the basic tune up stuff first?
Old 03-09-2009, 01:37 AM   #7
New plugs, wires, belts, filters, oil, cleaned air filter (could use some more cleaning though). Unless rotaries need other stuff too?
I'd like a wide-band to see whether its lean or not, but my budget for this car doesn't really support that. Plus, even knowing that, I still need to be able to do something about it. Plus, I'd like to know more about carb tuning just for my own insatiable thirst for knowledge and power.
Old 03-09-2009, 02:11 AM   #8
TheDriver216
Well you need to pull it apart and find out exactly what you have in the carb... Plus you could be down on power from just tired motor... You should do a compression test to find out if that is part of the problem as well. Dump a can of Sea Foam in your gas tank and put in a 1/4 tank of gas. and run it down to remove some carbon. Lots of little things... Have you changed the fuel filter as well?
And another thing... carbs are very testy to weather, it can run awesome in the summer but if you dont rejet or fiddle you might not run well in colder weather
Old 03-09-2009, 08:31 PM   #9
So then how would one fiddle with the side-draft? How comparable is it to a regular carb? I've found some online resources for regular style carbs, I'm hoping its the same?
I would also assume that the rejetting would involve purchasing new jets? Know any where that sells jets for Mikunis?
Old 03-09-2009, 11:33 PM   #10
PercentSevenC
Custom User Title
PercentSevenC's Avatar
I can basically only echo what TheDriver216 has said, since I, too, have only had experience with DCOEs. Run a can of Seafoam through it (even if it doesn't actually solve the problem, it always helps), and then pull apart the carb and document everything. Jet sizes, emulsion tubes, air correctors, venturis, etc.
If it's like a DCOE (and Mikunis are very similar from what I've heard), there should be idle mixture screws you can adjust, but that's about all you can do without swapping jets and so forth. I'm afraid I couldn't tell you where you can get Mikuni tuning parts anymore, though.
Old 03-11-2009, 01:22 AM   #11
Ok, thanks for your help. Do the jets and stuff have size markings on them? I'm going to guess that tuning would be very limited without being able to get other sizes? Guess I'll have to keep my eye open on evil-bay.
Old 03-11-2009, 02:27 AM   #12
TheDriver216
yeah most of teh time they are very easily marked... pull it apart and write it down... what color are your spark plugs? you can get a general area of how its running from plug color
Old 12-28-2009, 11:00 AM   #13
rotaryracer
rotaryracer is on a distinguished road
Nissan z-cars have Mikunis stock. I also am looking for help. I'll keep looking.When I find info, I'll post what I find.
rotaryracer is offline   Reply With Quote
Old 12-28-2009, 08:48 PM   #14
glassman
Premium Vendor
glassman's Avatar
glassman is on a distinguished road
I might know where you can get some jets etc but it's been a long time since I talked to them. The place is Overseas Distributing in B.C. 800-665-5031 or 604-879-6288 ask for Jim.
I have 4 - 44PHH Mikuni's if anyone is interested, 2 are BRAND NEW plus various jets and e tubes.
I also have 2 - 45 DCOE webers and 1 - 50 DCOE weber with 4 port 13B intake. Also have one of the star mazda intakes for 12A made by Pearce??
Mild to wild, street to strip, when you want to go fast and you want your engine to last, NRS Ceramics is the only way to go.
NRS Rotorsports
nrsrotorsports@shaw.ca
www.nrsrotorsports.com
glassman is offline   Reply With Quote
Old 02-12-2010, 09:22 PM   #15
striegels6
striegels6 is on a distinguished road
Sidedraft Help
Wolf Creek Racing. Owner has excellent advise and services. Stocks about everything for the Mikuni and webers. Rotary familiar.
striegels6 is offline   Reply With Quote
