Old 02-13-2009, 12:00 AM   #1
Corksport Oil cooler line defective.
So I was reading up on some guys build thread, in which he installed a set of Corksport SS Oil cooler lines.
I have purchased the same set, but when installing, ran into a problem with the radiator mounting point on the frame, which I had to cut off, because there was no other way to mount it up withought the upper line rubbing.
When I looked at the pictures in the thread, I was AMAZED at how much shorter my upper oil line was than the one pictured.
anyway, my worry is the kinks and the fact that I had to cut part of the car out to fit the line...
now i'm really pissed off that I got a shoddy part, and dont know if the company will still replace it because I bought it this past summer.
(Notice: The car has NOT been on the road after the install, and I have only had the engine running a couple of times at idle)
