Old 02-11-2009, 02:08 PM   #1
lcrotaryracer
lcrotaryracer is on a distinguished road
wtb, engine mounts and a oil pan gasket
i need the engine mount tanny mount and a oil pan gasket for a na s4. or tell me where to go in get them.
thanks
you can always have fun in a rx7
lcrotaryracer is offline   Reply With Quote
Old 02-11-2009, 03:47 PM   #2
Get Banzai's Poly mounts for the engine and trans. Use RTV to seal the pan.
Done!
Old 02-11-2009, 10:46 PM   #3
lcrotaryracer
will the pan seal good with rtv because i dont like to use it if i have to. where can i get those mounts.
Old 02-12-2009, 12:12 AM   #4
Turbovert
Turbovert's Avatar
Turbovert is on a distinguished road
www.banzai-racing.com
Skyler
'90 Vert Turbo. 3in, streetport, profec 2, ACT clutch and Flywheel, Apexi Power FC, BNR Stage 4, RC 750cc Primaries 1600cc secondaries, Coolingmist WI, Tanabe GF210's, Tokico Struts, 361rwhp and 288ft lb on 15.6lbs, no IC. Steve Kan tuned
Turbovert is offline   Reply With Quote
Old 02-12-2009, 12:20 PM   #5
permatex ultra black...
apply to the flange inside the bolt hole line of both surfaces, let sit for 3-4 min, then bolt up and let sit for a hour or so
Old 02-12-2009, 12:41 PM   #6
I would suggest OEM or Mazda comp motor mounts bought through your local dealer (unsure if they sell the comp mounts). The aftermarket motor mounts aren't as good and are not designed as well. If I recall correctly you have an N/A so there's no real reason for harder than stock mounts.
One very good thread: http://www.rx7club.com/showthread.ph...ression+mount*
Three quotes from RX7club.com
Originally Posted by digitalsolo
Yeah, to further what Ted was saying.
The bolt on those engine mounts passes straight through from the mount to the engine, creating a basically "solid" mount on tension (when the engine pulls away from the mount). They will "give" some when the motor pushes toward them, but that will likey be VERY minimal, as pulling toward one mount will typically mean pulling away from the other (not possible with the solid nature of the mounts).
The Mazda mounts embed the bolt in the actual cushioning material, meaning it can give both ways, which is going to be easier on everything from the cradle mount, to the engine mount attachment points, to the rear end (some cushioning will lessen shock loads on a launch etc).
If you want the Banzai style mounts, just remember you're really getting a basically solid mount.
In regard to the Energy Suspenion... I have them on my V8-FC, and I put some SERIOUS loads on it during acceleration and cornering, and I've been VERY happy with their performance, especially compared to ~20 year old rubber bushings. Any of the quality poly bushing sets should dramatically improve feel vs. stock rubber, and the increase in harshness is minimal with stock suspension, and the improvement in handling with an aftermarket spring/strut (or coilover) is dramatic.
HTH-
-Blake
Originally Posted by RETed
I don't know why anyone would want all that crap that is being advertised in terms of being an upgrade for engine / motor mounts.
It's just a piece of aluminum / plastic / polyurethane / etc. with a fricken bolt through it.
I've been bitching about these things ever since they became popular a few years ago.
These things work only in compression.
What happens in tension?
When the engine tries to pull against the bolt itself?
The aluminum / plastic / PU / rubber don't do jack shit when the engine tries to pull against the mount.
So what do you think happens?
You're right - the bolt BREAKS.
You're putting strain in the bolt and the metal engine bracket - something is going to fail.
Sure, these mounts are cheap, but there's a reason why they are cheap - cause they are easy to make.
Get a block of whatever - drill a hole in it - insert bolt / nut.
Viola - cheap ass engine mount.
Yes, they transmit a significant amount of vibration through the chassis cause it's going through the bolt.
I've seen one of the "popular" aftermarket engine mounts fail by the bolt breaking.
At least the stock mounts are design to handle the compression and tension forces of the engine.
These mounts actually pull a little when the engine pull against the two end studs.
This is why the stock engine mounts are best...or at least the stiffer Mazda competition ones.
I can see why race cars would go with solid mounts, but no street car should be running anything other than the Mazda units.
/RANT
I'm sorry but all those "aftermarket" engine mounts all "suck".
They only flex (if any at all) in just compression.
Under tension, they are fighting the bolt and nut!
The stock (and competition) engine mounts from Mazda are not designed this way.
The longevity of those engine mounts have not been tested yet.
Many are relatively new, and I don't think anyone has like 100,000 miles on a set yet.
Sure, they will probably never break, but I question the increased stress on engine, brackets, transmission, etc. cause the mounts just don't give under tension.
I'd recommend the competition mounts at under $50 each.
Old 02-12-2009, 08:45 PM   #7
Originally Posted by RotaryResurrection View Post
I am making over 450rwhp and using all stock mounts. There is no need for anything else unless you drag race or drift, which you have no business doing with a mostly stock NA 2nd gen anyway.
So my 17 second S4 isn't supposed to be quarter miled? Hmmm...
As for drifting, I suppose it would be easier if I could actually break traction at some point (on crappy Wal-Mart tires).
Old 02-12-2009, 08:47 PM   #8
yeah... but you'd be in a walmart parking lot so there wouldn't be any point...
Old 02-12-2009, 09:14 PM   #9
Hey, nothing wrong with shopping at Wal-Mart. Sure, it's pretty depressing to go to, but I can't say no to great prices and finding basically everything I need in one store.
Old 02-13-2009, 06:48 PM   #10
That's the problem with my fail-mart...they are half out of stock of EVERYTHING all the time. I havent figured out if this is because this particular store is just very busy and it is impossible to keep the shelves stocked, or if there is some supply or management issue particular to this store.
Every aisle you walk down looks like the day after Christmas, for real.
Oddly enough, this bone stock (2 stock cats!) 88 vert that I am about to put up for sale, will straight ROAST the right rear tire anytime you stab the throttle in a turn or on a hill. But it has hard old tires on it, so maybe that is why.
It depends on what time of day you go. I've gone before and they're out of a lot of stuff, but that's usually late at night before they restock. I would probably go to Target if there were one closer but it's a ways away.
Old 03-04-2009, 03:30 PM   #11
Hey guys, I have the banzai mounts.
One thing I want to know about RTED'ed and a lot of other people's comments is this:
have you people actually used the product? One little detail about the mounts, is that it's not just a bolt going through. The bolt threads through one of the metal rings, compressing the poly mount , and then you have the nut holding the mount. I'm NOT saying that people like RTed don't know their shit, but rather that what they are saying sounds like their "opinion" and perhaps they have not tried the actual product yet?
There are a lot of people that run Banzai mounts, and I have not yet seen a thread stating any problems with them. If you see such a thread, please show it to me, because I spent hard earned money on mine.
Old 03-06-2009, 06:15 PM   #12
classicauto
crash auto?fix auto
classicauto's Avatar
No no, you're not crazy.
They have their purpose. I'm running MMR's (same design basically, just with harder material) and I can flat out tell you that the solid AL blocks I ran before easily made 50% more vibration in the cabin.
My reason/need for going that route on my street car was keeping the engine in place. Sure there's other ways, but its my car damnit
