Old 02-03-2009, 10:42 PM   #1
MX722
MX722 is on a distinguished road
Electrical diagram for wiring up PFC
This includes ECU. Anyone have one or know where I can download one?
Much appreciation
MX722 is offline   Reply With Quote
Old 02-03-2009, 11:28 PM   #2
proz07
Needing a new tow rig.
proz07's Avatar
wiring up what its a plug and play ECU.
z
Old 02-03-2009, 11:50 PM   #3
David Jerome
David Jerome's Avatar
4 wires need to be cut for the car to idle below 2k rpms, you should be able to find it with a quick google search.
David Jerome
Old 02-04-2009, 03:58 PM   #4
MX722
Well the last owner of the car screwed something up. Now my commander won't actually command. Any input i put into it, nothing happens. It won't respond to any of my changes.
So i would like to rewire it from ground zero.
Old 02-05-2009, 01:50 PM   #5
Chadwick
Chadwick's Avatar
There is nothing to wire, it is a plug and play unit. As David mentioned there are 4 wires that need to be cut on the harness or pins removed on the PFC but they have nothing to do with the function of the commander. Are you getting a display on the commander?
Dan
93 RX7 BB (Race Car)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Old 02-05-2009, 05:17 PM   #6
Signal 2
Viable Fossil
Signal 2's Avatar
......my commander won't actually command. Any input i put into it, nothing happens. It won't respond to any of my changes.
It doesn't sound like your problem is with the ECU connection to the engine harness. It sounds like it's the connection between the Commander and ECU.
The connection between the Commander and the ECU is pretty sensitive, and even if it looks like the plug is all the way in, it may not be. Check that first. Mine did this once and the screen was completely blank. If that ends up being your problem... I resolved it by pushing the plug down all the way and then daubing some silcone around it and not moving it until the silcone set. It's now held firm and the silicone keeps any possibility of moisture or dirt out, but I can still pull it out if I need to.
IIRC, there have also been occasional issues reported on some units from the wire leads being too short as they enter the commander display. Simple movement of the cord over time can work one or more of the wires loose from the board inside the display head, requiring some solder work.
Jim
VR R1 FD
Old 02-05-2009, 11:06 PM   #7
MX722
Chadwick - Yes, i am getting a reading on the commander.
Signal 2 - I will have to look into what you mentioned tomorrow. Hopefully it will be something as simple.
