Old 01-29-2009, 12:24 PM   #1
Nopis1O
Nopis1O's Avatar
Nopis1O is on a distinguished road
200 hp questions?
Backround
Hey you guys im going to be running a 13b na with ITB's megasquirt, and probably a large street port. im hoping after its all said in done i will have around 200hp with other mods. my question is right now im not SP and im just seeing what i can get out of itb's.
Question. What kinda of Hp is safe with the stock Fuel pump and injectors and at what point should i upgrade. im thinkin for 200 or so a wall bro 255 and a bit larger injectors would be fine but what do you guys think?
THanks
1988 Fc Vert. Super Stock
1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
Nopis1O is offline   Reply With Quote
Old 01-29-2009, 12:36 PM   #2
You'd roughly be pushing 80% duty cycle on the 460cc's at 200hp. You could just get the TII injectors and fuel pump.
Old 01-29-2009, 06:50 PM   #3
RotaryProphet
If you're doing the Megasquirt tuning yourself, just keep an eye on your duty cycles, and you'll be fine. As a stop-gap measure, you can adjust the fuel pressure regulator (for ITBs, you are changing the regulator, no?) and bump the pressure up a bit. 60psi or so should see you a reasonable increase in injector flow, but settle on a flow rate before you start tuning.
Old 01-31-2009, 05:16 PM   #4
Flooder
Flooder's Avatar
I would get the TII injectors, they are 550cc and you'd be running less duty cycle with them. I wouldn't expect 200hp from a non-ported NA motor though. Even with the extra fuel.
I've done research on this before and it didn't seem worth the money. 200hp on an NA without a standalone is hard, if even possible on a non-ported motor.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Old 01-31-2009, 05:37 PM   #5
Ender
rotors excite me
Ender's Avatar
What about with an OPEN HEADER!! A great option if you're already deaf...
On a serious note though, if you haven't already gotten rid of your catalytic converter(s), do so because cats will hinder your efforts. If you can afford to you would do well to also get a high flow header, I hear Racing Beat makes good ones (and the rest of the exhaust if you want it). Sorry, I can't answer your actual question though, I'm a NA virgin (well, there was this one night stand, but I didn't take her home to mom and dad...).
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 01-31-2009, 05:51 PM   #6
Flooder
Flooder's Avatar
An open header wouldn't be the best option. I would get a racing beat header though. And then do a 2.25" or a 2.5" single exit exhaust.
AZRX7.COM
Red 1990 GXL(SOLD)
Old 02-03-2009, 07:25 PM   #7
Nopis1O
Nopis1O's Avatar
yes i plan on a racing beat hearder. and i know not to expect 200 non ported. if you read my OP i said once it has a large SP light weight clutch flywheel and other misc. odds and ends i would like to be right around 200.
Old 02-03-2009, 07:29 PM   #8
FYI- you will only need the 550's for secondaries. No reason to have a pig rich idle.
Old 02-03-2009, 08:37 PM   #9
the exhaust and the porting are going to be the two things that will really make that number happen and they have to compliment each other.
Old 02-03-2009, 10:13 PM   #10
Rotary#10
Rotorhead
Rotary#10's Avatar
kinda like peanutbutter and jelly mmm mmm !
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 02-04-2009, 04:21 PM   #11
I dunno, I really want to see what my motor will get after the car is done and the rtek is tuned, to give a baseline for Bobby's (nop1stons) itb setup? I'm sure that whatever I get, a proper itb setup, full standalone, porting, and good tuning will make more, and I'm shooting for hopefully 150 whp? Ludwig told me not to set my sights on a number, but I think 150 is safe to hope for with an S5 motor, full exhaust, no emissions and a rtek?
Old 02-04-2009, 04:57 PM   #12
drewski86
Slow
drewski86 is on a distinguished road
You say you plan on getting a Racing Beat header but you haven't said which one. The street header is a bit short for stock ports, and will be worse if you port the exhaust. I would suggest the road race header collected shortly after the flange(will vary depending on your ports and peak RPM) or the AWR header which is built for streetported road race cars.
If the motor is in good condition you should not have a problem breaking 160whp. My 180k mile S4 motor was right around 160whp with stock ecu.
drewski86 is offline   Reply With Quote
Old 02-04-2009, 05:59 PM   #13
a premade generic header will probably not be suited to max your max power goals.
Old 02-04-2009, 06:51 PM   #14
Flooder
Flooder's Avatar
I made around 160 wheel in my S5. It's not unattainable at all. Especially with an ITB setup.
AZRX7.COM
Red 1990 GXL(SOLD)
Old 02-05-2009, 10:45 AM   #15
Roen
Evil Club Mod
Roen's Avatar
ISC Full Exhaust system is the best for power, but it's the loudest system. It's usually made for track only cars but if you really want the power number, then be prepared for a lot of noise violation tickets.
200 whp will still be tough with a large SP, ITB's and a Racing Beat Exhaust.
I made 161 whp using a GTUs with a K&N Drop-In Filter Replacement, Racing Beat Collected Header, Racing Beat Pre-Silencer, Racing Beat Cat-back and Rtek, with fuel and timing tuning on the dyno.
Run 4 x 720 if you're going to change the injectors, no reason to pussyfoot with 550's unless you get a good deal with them. Since you have a megasquirt and you'll be tuning from scratch, you can just turn down the duty cycle at idle or anywhere else you need to lean out the fuel curve. I'd also get a pump as a precaution, because the last thing you want to do is run out of fuel.
fuel pump, itb
