Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Prosport Gauges
Prosport Gauges www.prosportgauges.com (FL) Offering affordable performance gauges with the hottest design & exceptional quality
Old 01-26-2009, 03:20 PM   #1
Prosport Gauges
Prosport Gauges's Avatar
Prosport Gauges is on a distinguished road
Affordable Wideband Air/Fuel Ratio Gauge kit
$229.00
Wideband Air Fuel Ratio Gauge
52mm (2 1/16")
0-5 volt
Utilizing the latest Bosch wideband O2 sensor -5 wire heated LSU 4.9 our gauge now has the widest range 10.0:1 to 20.0:1 AFR readings on the planet.
Featuring Blue LCD readout in the center of the gauge and a bar-graph syle LED's around the outside of the gauge that change from green(Rich) to Yellow(Optimal) to Red(Lean) for immediate reference to AFR.
This is a complete kit that includes everything you need:
AFR digital Gauge
Bosch 4.9 5 wire heated O2 sensor
Weld in Bung
Instructions
Wiring harness(Gauge to O2 sensor) Plug and play
Decals
Visor/hood
Prosport Gauges is offline   Reply With Quote
Old 01-26-2009, 04:11 PM   #2
Awesome!
For some of the newbs thinking about getting this for your FDs.. The location of O2 sensor is important.. Too close to your turbos will over heat the O2 sensors..
Or you could get a heat sink adaptors or make one of these..
I'm Very interested in getting one of these!
Prosport, would it be possible for you guys to make the copper shields like that and sell it with the kit??
I know rotaries tends to run much hotter than pistons..
Old 01-26-2009, 04:32 PM   #3
Prosport Gauges
interesting.. does it have to be copper ?
Old 01-26-2009, 05:35 PM   #4
Not really. Copper just conducts heat well, so does aluminum. I imagine that any metal used in radiators will work well for a heat sink.
Old 01-27-2009, 07:30 AM   #5
Prosport Gauges
I think alum. is less expensive now and looks better over time.
Old 01-26-2009, 06:50 PM   #6
I believe that would be the cheap alternative to it..
Here is an Innovate's heat sink... But its $70-80... I think??
Here is a pic of it..
Old 01-26-2009, 04:44 PM   #7
rx7 FC TII
rx7 FC TII's Avatar
rx7 FC TII is on a distinguished road
ya id be very interested in one of these also. i know if it included the heat sink i would be even more interested.
i was gonna get a innovate but thats gonna run pretty high for me.
rx7 FC TII is offline   Reply With Quote
Old 01-26-2009, 05:26 PM   #8
hmm....ill be getting one this as soon as i can.
How will the sensor work with E85?
Old 01-27-2009, 12:21 PM   #9
how much for the gauge only? Also, I like the heat sink idea.
Old 01-27-2009, 01:27 PM   #10
Prosport Gauges
$229.00 For the wideband kit. Gauge, wiring, Bosch O2 sensor, weld in bung, instructions & visor/hood.
Old 01-28-2009, 08:32 PM   #11
AHarada
Is there another 0-5V output that can be used for datalogging? Or would you need to tap the signal to the gauge?
Do you have a picture of the controller?
Old 01-29-2009, 10:13 AM   #12
Prosport Gauges
No datalogging output.
I do not have a picture, but they are small about the size of a zippo lighter.
Old 01-29-2009, 06:51 PM   #13
still interested in how it would work with E85
Old 01-30-2009, 09:21 AM   #14
afterburn27
afterburn27 is on a distinguished road
Unfortunately you are going to lose lots of interest because there is no 0-5V datalogging output. Without it the unit is pretty much useless for tuning.
I don't think Bosch sensors have any issues with E85...
'93 RX-7 (GT3574 track toy)
'74 Triumph TR6 (weekend cruiser)
afterburn27 is offline   Reply With Quote
Old 01-30-2009, 07:56 AM   #15
Prosport Gauges
It is completely universal, as it comes with everything you need.
wideband
