Old 01-23-2009, 06:43 AM   #1
SleepeR1st
SleepeR1st is on a distinguished road
Exclamation 1988 Turbo II, rebuilt, $3500, NH
Feel free to go through my albums labeled "RX7" and "My Engine".
http://s143.photobucket.com/albums/r153/SleepeR1st/RX7/
Body has 109k miles, as you can see from the pictures it is extremely clean, and i know of only one rust spot on the car, which is a small spot on the sunroof. Underbody is very clean.
Engine is a Kevin Landers/Rotary Resurrection rebuild. Complete Mazda OEM rebuild kit, 2mm seals.
Has a large streetport done by Crackheadmel from the forums.
The Goods:
Rebuilt engine! Engine runs, has great oil pressure, havent checked compression.
Comes with all of the following but not installed, SAFCII, AEM Uego Wideband, Autometer Lite Boost/water temperature gauges in an A pillar gauge pod.
S5 turbo rebuilt by SHOWA, with an s5 manifold, never used it, but no shaft play, looks great.
Complete front brake setup, Frozen Rotors, rebuilt 4 piston front calipers, SS lines, Hawk HPS pads, less than 1k miles on them.
Racing Beat exhaust, downpipe, y pipe, mufflers, not the Rev II, original style.
Interior is very clean, no stains, no rips, just 1 cut in the center bin.
The Bad:
Exhaust could be tightened down to the wastegate a little more.
Idle issues that i can't figure out/don't have patience for figuring out.
Full emissions removal, no AC, no power steering (de-powered the right way), no BAC.
Needs tires? Lol
There's really not much bad things about this car. It's a perfect starter RX7 if you don't mind getting your hands a little dirty and figuring out some idle issues.
I payed $2800 for this car running very poorly before the rebuild. I spent the $900 on a rebuild kit to try and rebuild the engine myself. I pinched a water seal and didn't want to take the engine apart again, so i payed for another rebuild by Kevin Landers.
I have a lot of money invested in this car for almost no satisfaction on my part, i have not driven it yet.
SleepeR1st is offline   Reply With Quote
Old 01-25-2009, 07:18 PM   #2
sickofpistons
sickofpistons's Avatar
sickofpistons is an unknown quantity at this point
Would you be interested in any type of trades? Is there any issues with the turbo?
sickofpistons is offline   Reply With Quote
