Old 01-18-2009, 12:07 AM   #1
lcrotaryracer
lcrotaryracer is on a distinguished road
dosent idle, fuel cuts at high rpm
well i removed emissons to the tee as on kevins site but i can not get it to idle. i fuel cuts at high rpm mostly in 2nd and 3rd gear
the car: 87 nt has new fuel and air fillter new sock on the fuel pump all the lines replaced do to rust in the tank "hell to clean"
it runs strong. a litte mis at times
thanks tim
you can always have fun in a rx7
lcrotaryracer is offline   Reply With Quote
Old 01-24-2009, 10:15 PM   #2
Ender
rotors excite me
Ender's Avatar
You may have simply left something open/disconnected/leaking when you pulled emissions. It's easy to miss something or not get something snug, I and many others have done it before. Did you pull the air pump or reroute the auxiliary intake port activators?
And at what RPM(s) does it cut fuel? I think the NA 2nd gen's are supposed to cut fuel somewhere above 8k (I've only had my '87 TII which cuts lower so I'm not sure).
Buy one of these, whether you think you have a vacuum leak or not, it's infinitely helpful. NA or turbo, it'll still show you potential leaks in your intake. A damn fine deal for $25, my TII ran ok before I used it, then I found at least 5 different leaks then it ran like a RAPED APE, MAN! Loud and fast as hell
http://boostpro.net/prodtester.html
If you have an air compressor then get this one:
Boost Leak Tester (Gauged)
3" Diameter
With Male Compressor Coupler
$20 + $4.60 shipping
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
